    Dec 2019
    Germany
    Question EDC17CP14 - Limp Mode remove for one DTC
    Hello, i have a problem with EDC17CP14. The ECU is damaged, EGR control does not work. We have disabled the EGR and removed DTC with DTC Remover. Engine lamp is off but limp mode stays.
    What can we do to remove limp mode for this DTC?
    Best Regards
    Christian
    Jul 2017
    post here original file, i can do best file for you.
    Dec 2019
    Germany
    I have attached the OriFile, EGROff File and DTCoff File.
    Thank you
    File Contents: Eeprom, Oriflash with ImmoOff, Oriflash with EGROff and Oriflash with EGROff and DTCoff
    momogsm's Avatar
    Just Say Momo, I Will Be Here. ��
    HI
    EGR OFF, CHECKSUM CORRECTED
    PASS IN PM
    REPORT BACK
    THANKS
    IF I HELP YOU DO NOT FORGET TO CLICK ON THANKS AND REPUTATION
  5. The Following User Says Thank You to momogsm For This Useful Post:
    audigy200 (15th February, 2020)
    Dec 2019
    Germany
    I will give you Feedback when Car is back
    Jun 2009
    Why you switch ETCtl_swtActv_C in your file ?
