what about self starter on one as well
forcus C-max
Bet customer thought he'd come in to Arkwrights shop in open all hours
customer comes in for broken spring on n/s/f
Leaves with a bill for nearly a grand.
Pulls the vehicle in N/S brake binding like mad, removed wheel caliper rubber torn and piston corroded, customer advised, "do what it needs" was the retort.
Caliper, pads, spring still binding, cable poor , i'll fit a cable, nothing at the after market boys, try the stealer, yes need new complete unit 620+
WTF
can't they design one with detachable cables ****s.
changed one on a disco3 that lived in the sea, I think that unit was only about 300 but the labour made up for it.
Ted
Ted cable? What the cable for?
handbrake cable, from motor to calipers
Peugeot 306,RHD.
Brake switch change.
Nice one!
Yeah drop the colon, SLICE your hand charge costomer lots of money.
Pug 406 - same, had a bet with "Nosher", drop colon, and fit - no idea how he did it, but he DID do it in like 15 mins, without dropping the colon - cost me a horse burger that did.
something about he did it through the clutch pedal from behind!?!?
Next one 4 M8 bolts drop left hand in and slice it as required much much eaiser
Try it lot better way
I must agree with all ya, Frech are the most fu**ed up manufactures.
I personally own Acura RL 2006, they have touch sensors which eventually fail, anyway i have decided to fix them. Well the door handle i singleuse only, but i have dissassembled without much damage, take out he sensor... And gues what! There are writen in BIG letters - VALEO. And thats french...
No matter how many peugeots, citroens i have repaired (eletronics) they all are the same brand, but they are fuc**ng diffferent. You just cant remember what was where, because colors, nubering and locationsa are different in each car!!
No Signature
You have to be really careful these days when take a car apart, if not,when put together, you may end up with a different brand
I got used over the years not to blame the brand or nationality of the car...........siemens/bosch/valeo/trw/luk/sachs/ngk/beru/....
and so on is written all over the parts that fail ....
Manufacturers fail big time on the drawing board....
A bulb failure is NOT a malfunction and should be an easy job to do !
Try do this in the middle of the night by the side of the road (that is the time most drivers notice!!!)
[ame="http://www.youtube.com/watch?v=t_y0OJB0Nl4"]Smart Car Front Panel Removal Change Headlamp headlight bulb light - YouTube[/ame]
A failure will not appear till a unit has passed final inspection
Swamp body panels.....
These guys are the best at this kind of crappy jokes....
Sorry excuse for a paint job.....
