Results 1 to 7 of 7
    Default 2018 Toyota Sienna -tssop 93C66 is write protected
    This Eeprom tssop 93C66 is write protected.
    Reading the Eeprom is ok.
    Can I replace it with the same tssop ordinary Eeprom
    so that I can write in the new km?
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Yes, you can.
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Anything different written on the chip to see it is write protected
    'If I helped, please click Thanks +Reputation.. !'
    May 2011
    hi
    which tool you use to read ....???
    I use Mtool - read ok but cannot write on the write protected line that are line from 0000 to 001F
    take cluster apart & read/write in-circuit with upa . same thing read ok, write not ok
    correction - Eeprom is not TSSOP. it's MSOP. ordered the TSSOP yesterday & got it today & I realize
    I actually needed MSOP. Not sure now MSOP are design with write protected require write protected programmer?
    Nothing to panic. The MSOP Eeprom need to be de-mount from the board to
    do whatever you want. Replacing the Eeprom not gonna help to avoid
    the write protected situation if it is not de-mount from the board.
    Feb 2019
    Is not a tmsop 8? (2.9 x 2.8 mm)
