Results 1 to 9 of 9
    Default Ford Focus 2013 bcm clone
    Hello all I have here a Ford Focus 1.6 tdci year 2013 that I need to replace the bcm on I have a used unit and copy all data across using forscan but it has not transferred the immo data. I have vvdi prog so was gonna use these connections:
    Question really how to open this bcm must the plastic rivets be drilled in the corners? I can see and feel there are clips all round the side.
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Just lift all the clips around the box, and try to pull it into 2 parts. It is easy to do with a screwdriver.
  3. The Following User Says Thank You to PocketHero For This Useful Post:
    Galee (26th February, 2020)
    Hi thanks I got it apart and connected vvdi prog to read the data but I get this error any ideas?
    Oct 2017
    Check your soldering. Do you have a pic of the soldering you did?
    Oct 2017
    Flux is your friend as well as solder.
    Yes mate I redone it it had conformal coating so had contaminated the solder a bit.
  9. The Following User Says Thank You to Galee For This Useful Post:
    PocketHero (25th March, 2020)
  10. #8
    Jan 2021
    What files do i need to save to replace my dead bcm with a used one? i have the same errors and soldering is all good. need to set sizes manually does anyone have the info? also do fuses need to be in to read?
  11. #9
    Jan 2021
    Anyone help with sizes?
    I havent erased anything.
    I have eeprom as 0
    D flash as 32kb
    P flash is 1mb
    Pof is 64kb.
    Is that correct
