    Dec 2017
    Default Honda Civic EDC17C50
    It’s Honda Civic 2.2 on 2012 EDC17CP50
    It’s showing codes P0122 & P2135 and it’s in limood due to these fault codes
    Customer has changed the new throttle body ect
    But it’s still showing the same codes and still in limood
    I think it’s the ecu which may have gone faulty
    What I’d need to know is if I delete these codes P0122 & P2135
    Will it come off from limood or better to replace the ECU
    If replace the ecu is it easy to clone on this
    sniegavirs's Avatar
    Mar 2017
    Latvia
    17cp50 not C50
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Check the wiring first
    Dec 2017
    Jul 2012
    Quote Originally Posted by Happy786786 View Post
    It’s Honda Civic 2.2 on 2012 EDC17C50
    you read the original file ... before replacing the ecu I would try to remove the dtc present for you and then see if this worked ...
  6. The Following User Says Thank You to mario38 For This Useful Post:
    Happy786786 (26th February, 2020)
    Dec 2017
    Quote Originally Posted by mario38 View Post
    Tanx I will
