Results 1 to 15 of 18
    Aug 2008
    Default Mini R56 2008 - What do I need to program a new smart key?
    I bought a blank smart key from eBay, ID46 - PCF7952 868mhz. Trying to create a spare key for Mini R56 2008.
    https://www.ebay.co.uk/itm/3-Button-Remote-Car-Auto-Flip-Key-868MHz-ID46-Chip-Fob-Fit-For-BMW-Mini-Cooper/362906561348?ssPageName=STRK%3AMEBIDX%3AIT&_trksid =p2060353.m2749.l2649
    I am wondering what tool what I need to clone the original, as I don't have a spare.
    I read that FVDI may do it? Then I get confused is the R56 CAS3 or CAS3+? And can FVDI do this?
    Any help would be appreciated.
    ghostrider72's Avatar
    Jul 2012
    UK
    Well... if you don’t have equipment to code keys for Mini than best way eill be to get local locksmith to do it for you. Simply not worth to buy tools to do one car.
    Aug 2008
    It's hard to find anyone to do it around my way, what I would do is buy the tool and then sell it on. I've found doing this before works out cheaper.
    Dec 2016
    Quote Originally Posted by zeroprobe View Post
    YES FVDI kill CAS3+ ITAP , VVDI2 too when higher upgrade ...
    happy inform to you , an dealer BMW key is available for 150€
    Better is to dismantle all car for remove CAS3
  5. The Following 2 Users Say Thank You to TERMINATOR1000 For This Useful Post:
    A22 (26th April, 2020), Hayssam1 (1st March, 2020)
    Mar 2018
    UK
    If is hard to find locksmith to program the key in your area try to imagine how hard will be to find someone to fix the car after your programming
    Apr 2016
    uk
    Get this tool and you will be fine..
    https://www.microtronik.com/order-on...ackage-ahx0005
  8. The Following 2 Users Say Thank You to comizelu For This Useful Post:
    fred77 (2nd March, 2020), ghostrider72 (26th April, 2020)
  9. #7
    Dec 2016
    it's for ADD key , he just need to remove CAS3 of the car ( 3 hours job ) , read key data & made it !
    i think than for 1000$ he can do it !
    If AKL he need need to read ECU ISN ... but another story
  10. #8
    Apr 2016
    uk
    Quote Originally Posted by TERMINATOR1000 View Post
    He asked for a tool to do the job.
    Because he doesn't know much about this job it's safer with this tool!
    Also,to make him understand the cost we have to pay for the tools..
  11. The Following 2 Users Say Thank You to comizelu For This Useful Post:
    fred77 (2nd March, 2020), Manta1600 (2nd March, 2020)
  12. #9
    fred77's Avatar
    Jun 2019
    Rub 2 sticks together - job done
  13. #10
    Aug 2008
    OK understood, thanks for the information.
  14. #11
    rob h's Avatar
    May 2011
    If you remove the cas3 yourself,
    You will need a programmer to read data.
    R270 from china is cheap, and works fine.
    Then you still need to have a tool that writes the data in your new key.
    And Cut a key.
    If you take all this effort, the risk, the time, the money.
    Consider either find a locksmith that dares to to do this job by obd.
    Or remove the the cas yourself and send it, to a locksmith, or a trusted D.K member in your country.
  15. The Following User Says Thank You to rob h For This Useful Post:
    zeroprobe (2nd March, 2020)
  16. #12
    Aug 2008
    One last thing, what about VVDI2 BMW, VVDI is well trusted? and done by OBD2?
  17. #13
    Mar 2018
    UK
    In this forum you can find few threads for faulty CAS3+ after all chinese tools also VVDI
    in fact chinese can't make trusted tool for CAS3+
    Comizelu already told you what is the cheapest trusted tool that you can use for CAS3+
  18. The Following User Says Thank You to Manta1600 For This Useful Post:
  19. #14
    Aug 2008
    Just an update.
    I bought a VVDI BMW.
    The R56 mini was CAS3+ not encrypted so I didn't need to downgrade, so less risky.
    Added the key perfectly.
    I don't envy those who do this for a living. High risk low reward.
  20. The Following User Says Thank You to zeroprobe For This Useful Post:
    sleepyrz (26th April, 2020)
  21. #15
    Feb 2018
    Glasgow area
    You bought VVDI BMW to do one key for your own car?
