Hello Guys,
I need to clone a Crafter ECU as said above, but I'm not that experienced with this ECU.
What happened:
I wanted to DPF off the Crafter ECU 076906022M EDC17CP20-2.39A CEBA 0281016822
opened it, read backup with Kess V2, read only Flash, modded flash and wrote the DPF off flash back. When I installed the ECU in the car it dies. The high voltage driver for the injectors shorted through the heat sink/glue to the ECU housing. I guess the drivers are damaged, ECU draws high current and gets warm. So I got another ECU 076906022Q EDC17CP20-2.39A CEBB 0281016820.
I read backup and flash too for security and then wrote the backup of the old ECU.
The car wont start due Immobilizer. Immo control module says, that ECU hast to learn the vehicle an Immo data. But I dont have any PIN.
Maybe this is because of the OTP area not fitting the eprom, as I read in other forum?
The other three files are read with galetto from second ECU after the old Backup was written.
Maybe someone can help me with this files?
If neccesary I will write back the backup of the second ECU and read with galetto to provide original micro, flash and eprom data of second ecu.
And I will try to bring the first ecu back to live with desoldered high voltage drivers to read it with galetto too.
greets and thanks in advance
