Results 1 to 15 of 19
    Yhoni's Avatar
    Jun 2014
    Somewhere in time...
    Default IMMO BSI SIEMENS E01-00 HG Xsara Picasso?
    Hello, I continue with the citroen xsara picasso since the car does not start and we have already tested two injectors, the bsm and the ecu that is correctly made the immo thanks to Rafal.
    Now we believe that the BSI also suffered from the same short circuit that burned the ECU and I have a used SIEMENS E01-00 HG, I have already read the eeprom 95160 but now I don't know how to continue.
    Is it possible to eliminate the immo from the eeprom or should it virginize and then encode?
    What exactly is virginizing?
    I do not have that knowledge and it is the first time that I have to do it for what I would appreciate some help.
    Thank you
    The first post:
    https://www.digital-kaos.co.uk/forum...hlight=edc15c2
    If my post has helped you, do not forget to click on the "THANKS" and "REPUTATION" button !!!
    I do not answer in private questions that can be solved in public.
    kiszka's Avatar
    Quote Originally Posted by Yhoni View Post
    Thank you
    The first post:
    buy another BSI with the same number and key
    mount to the car,
    save original from VIN car to bsi
    and enjoy driving your car
    and for messages that there is a lack of immo one has to get used to
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  3. The Following User Says Thank You to kiszka For This Useful Post:
    Yhoni (5th March, 2020)
    Yhoni's Avatar
    Jun 2014
    Quote Originally Posted by kiszka View Post
    mount to the car,
    Ok Kiszka, and to record the car vin in the bsi can I do it directly by editing the .bin file of the eeprom 95160 or do I have to do it with the diagnostic machine and doing some kind of coding?
    Would it be a good solution to copy the reading of the eeprom 95160 of the bsi that came in the vehicle into the eeprom of the new bsi, to clone the eeprom directly?
    Thank you.
    kiszka's Avatar
    Thank you.
    vin just by coding
    this is the easiest way
    all other ways add robots
    a full BSI clone, you can still do it
    Reality of life :
    4:Everyone lies
  6. The Following User Says Thank You to kiszka For This Useful Post:
    Yhoni's Avatar
    Jun 2014
    vin just by coding
    Ok, so I have to use a diagnostic machine like Launch to encode the VIN in the bsi. Right?.
    What do you mean when you say "add robots"?
    Can I clone it only by copying the eemprom from one bsi to the other or should I also read some flash memory?
    Thank you very much for the information you are giving me.
  8. #6
    kiszka's Avatar
    flash and eeprom
    Reality of life :
    4:Everyone lies
  9. The Following User Says Thank You to kiszka For This Useful Post:
    Yhoni (24th March, 2020)
  10. #7
    Yhoni's Avatar
    Jun 2014
    flash and eeprom
    hello, the PSA bsi that I have to clone is this siemens "E01-00 HG" with eeprom 95160 and NEC processor "D76F0018GJ" but I don't know what the flahs memory I should read.
    I have tried to weld the old eemprom 95160 in the bsi we bought second hand but now the diagnostic machine gives me the vin: BBBBBBBBBBBBBBBBB and communication error with the ECU (which has immo off) but the car does not start the same.
    Could you explain to me how exactly I should clone it?
    Many thanks.
  11. #8
    belgrade,serbia
    c5 2.ohdi bosch 3 dzeka.rarhere you are example for immo off change flash in engine ecu like example no need check sum.for bsi isend you virgin dump and you have to program with lexia
  12. The Following 2 Users Say Thank You to vladanr For This Useful Post:
    pekelan (4th August, 2020), Yhoni (7th March, 2020)
  13. #9
    Yhoni's Avatar
    Jun 2014
    Ok Vladanr, our forum partner "Rafal" made the immo off of the ECU edc15c2 correctly in the eeprom and flash.
    Do I need to modify the flash of the ecu again and program the file that contains the rar you shared "c5 org flash.immo off.bin"?
    Thank you.
  14. #10
    Yhoni's Avatar
    Jun 2014
    Quote Originally Posted by vladanr View Post
    Thank you.
  15. #11
    belgrade,serbia
    check rafa file is there same changes as file i send you ,if not change your org file with ff on location as example i send you and start car
  16. The Following 2 Users Say Thank You to vladanr For This Useful Post:
    pekelan (9th August, 2020), Yhoni (24th March, 2020)
  17. #12
    belgrade,serbia
    Xsara Picasso Carr.rarHERE YOU ARE I MADE YOUR FILE OFF
  18. The Following User Says Thank You to vladanr For This Useful Post:
  19. #13
    Yhoni's Avatar
    Jun 2014
    Ok Vlandanr, could you send me the password , please?
    Thank you.
  20. #14
    Yhoni's Avatar
    Jun 2014
    Hi, Rafal's flash file and yours are the same. I have used a hexadecimal comparator and they also have the same hash so I think I do not need to open the ecu.
    So do you know if I just need to program the eeprom 95160_VIRG.BIN and code with Lexia? is this correct?.
    Thank you.
  21. #15
    Yhoni's Avatar
    Jun 2014
    Hi, this is the information contained in the text file inside the immo rar:
    "od 3e628 fova do 3e660 do c3 staviti ffff"
    What does the author mean is that all C3 must be replaced by FFFF from position 3e628 to 3c660 of the flash memory?
    I ask because in the flash.immo file in those positions there is no FFFF and I am a bit disoriented with that.
    Thank you.
