Results 1 to 7 of 7
    Aug 2015
    Default TMS374 xprog-m read problem
    Hi, i`m trying to reed tms374 form fenix5 ecu with xprog,
    chip is desoldered and mounted in adapter using instructions from:
    https://www.digital-kaos.co.uk/forum...dapter-TMS-374
    i checked connections many times, everything seems fine but i still get "bootloader initialising error"
    Thanks in advance!
    xprog 15v power supply
    Aug 2015
    i connected power supply,
    when i try to read mcu current rises, but still same error
    "bootloader initialising error" could be an indication of all connections are correct but the problem is inside xprog box!
  5. The Following User Says Thank You to Zmann For This Useful Post:
    wodorof (7th March, 2020)
    Aug 2015
    until now it worked like a charm,
    is there way to confirm that programmer is damaged?
    Quote Originally Posted by wodorof View Post
    The error statement is common to Xprog but for these MCU's the problem is more or less specific and due to Xprog HW.
