Results 1 to 5 of 5
    Oct 2018
    Default Wiring diagram for Opel Astra J
    Hi friend I need help with electrical diagram for OPEL ASTRA J 2015 engine code B16DTL ,1,6CDTI Euro 6.
    I have short to battery erorr on Oil solenoid Valve.
    I atach the diagnostic code.
    eliasole's Avatar
    Cant upload image
    solenoid pin to ecu is pin a75 (a) plug ecu is 96pins, cable colour blue
    Feed is fuse f2 10a that also feed intake manifold air control actuator and oil jet piston control , colour violet/blue same at all and pin at engine fuse box c6
  3. The Following User Says Thank You to eliasole For This Useful Post:
    Walter2011 (7th March, 2020)
    Oct 2018
    Thanks you friend! If can pls send photo me email xxxxxxxxxxxx
    Thanks!!
    Jan 2020
    Dziękuję przyjacielu! Jeśli możesz wysłać mi zdjęcie e-mail xxxxxxxxxxxxxx
    Dzięki !!
    Poszedł do pw.
    Oct 2011
    Germany
    2 years later....
    1.6 CDTI Delco E98 Wiringdiagram
    As with any good forum, this one begins with post number 1 on page 1
    It doesn't hurt to hit the thanks button
  7. The Following 2 Users Say Thank You to bergbahn For This Useful Post:
    jeg (5th April, 2025), motor25 (4th January, 2023)
