Results 1 to 9 of 9
    Apr 2019
    Default KESS v2 Checksum error when loading file for writing
    Hello.
    I cant find any info why this error keeps happening. I could read without problems from edc15p+ but when i try to write it just gives me checksum error when i choose file to be written.
    File is corrected by winols.
    I tried multiple files also the original file which was red by this tool to be written but same error.
    Funny thing is i could read and write on edc16u1.
    Which is corrected also by winols.
    Any help would be appreciated i am totaly frustrated of this. I payed for damos prepared my file and now this 5H*T.
    Thank you
    EUROPE
    Galletto can do your job even 1260
    dehacko's Avatar
    Feb 2018
    SK
    which car ?
    I tried read and write edc15p+ no problem kess chinese clone
    very good tool for edc15p+ is cheap mpps16 clone, 100% solution and boot mode, chs worked correctly
    Apr 2019
    Its a fabia mk1 with atd engine. I will try mpps it failed on my edc16 seat leon after 100 writes maybe it will work wirh edc15..
    Apr 2019
    Well mpps did not work. It tries to connect then just drops error and thats it. I dont know guys maybe the ecu is bad. I should be able to start the car as is without abs controller but it just cranks and does not fire up. Also seems like injectors does not work because apsolutely no smell of fuel coming of it. Funny is no errors except missing massage from abs and brake switch signal implausible.
    Feb 2020
    https://youtu.be/D0Rp-wN50JY
    IT helped me bro
  7. The Following 2 Users Say Thank You to marcin95pl For This Useful Post:
    msms0904 (9th March, 2020), speedy100 (17th March, 2020)
    Apr 2019
    Exactly what i done before you posted it i just came back to tell you that you just need to download official ksuite then install and overwrite it with your files and it works.
    But my car still does not start... At least i coud flash it now.
    speedy100's Avatar
    Athens
    Quote Originally Posted by marcin95pl View Post
    I wish it was in English... can not understand a thing
    Best Regards
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
  10. #9
    n1gh7r1d3r's Avatar
    Jan 2025
    Bulgaria
    Ok so .... You unnistal the chinese kess install the original... uninstall the original... install the chinise, correct?
    [COLOR=var(--IXoxUe)][/COLOR]All the gods, all the heavens all the hells are within you!
