Results 1 to 11 of 11
    May 2013
    Moldova
    Default Virgin/New firmware for AC Delco E78
    Hi to all, i have a Chevrolet Volt 2012. And i want to change ECU (AC Delco e78). I bought another one that is used.
    The numbers from ecu that i bought is exactly the same as my old ecu.
    Can someone please give me the Virgin file/New File for AC Delco E78.
    I want to program it with SPS.
    I will use the I/O terminal.
    Thanks Beforehand !
    Aug 2018
    East Pole
    Hello. Clone it with iot andthat will be all.. Or the old ecu does not respond to diagnose?
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by radu1411 View Post
    Thanks Beforehand !
    You have ioterminal...
    Copy and paste mpc...
    That's all...
    There is no separate Eeprom...
    Aug 2018
    East Pole
    Some of this people stick good money into good tools, but never learn to use it. Acdelco license is about 500euro.
    Radule, clone the damn ecu and get back your money spent for iot...
    May 2013
    Moldova
    Quote Originally Posted by volorucinski View Post
    The old ECU is dead. I kill it, when i was writing the firmware with the kess.
    The only way to unlock it, is if i have the Shadow password. But i dont have it
    figani's Avatar
    Feb 2018
    Check wiring diagram from ioterminal...
    For this kind of ecu Andrius also has a boot pinout...
    It's easy, check wiring diagram...
    Need only 200ohm resistor...
    May 2013
    Moldova
    Quote Originally Posted by figani View Post
    I tried with 200 ohm, and to solder 2 point. But it didnt help me.
    I searching the Virgin firmware for that ecu, to program it through SPS .
    Aug 2018
    East Pole
    Q: do you have access to the car from where you bought the second ecu? You could connect sps on that car and make the ecu virgin. Then, go on your car and proogram it. You know that sps can reset the ecu if it is on the car where have firstly been coded.
    Post edit: or buy the bcm annd get pincode from there and try resetting the ecu
    May 2013
    Moldova
    I cant get the pass or bcm. May be exist another method ?
    peko's Avatar
    anybody tested via OBD with bitbox ?
    Dec 2022
    volorucinski Cual seria el proceso para que sea virgen desde el carro donante? Gracias.
