Results 1 to 2 of 2
    alex_r_2001's Avatar
    New Jersey ,, USA
    Default Me17.9.1 used ecu install help
    Hello everybody after reading though out the forum I'm getting a little confused... I looked on fvdi and only ecu selection that looks like this ecu is edc16c39 but I did not want to try that because I dont know if its compatible ... So then I checked on vvdi prog and it has the selection for me17.9.1.. Will vvdi prog be able to clone or change the vin a used ecu..... I was reading something that this ecu is encrypted... Other tools I have
    Vvdi prog
    Vvdi 2
    Fvdi 2018
    Autel ms908
    Auro IM 508
    Londsor k518
    Snap on junk
    Tango
    J2534 Pass thru programmer
    Smart box key programmer
    And other misc key and eeprom programmers
    New Jersey ,, USA
    I tried with vvdi prog no luck it connects and tries different security bytes but says failed to crack... Any ideas are appreciated thanks friends.
