    Apr 2016
    Default Opel Astra H Dashboard problem P0650
    Hello evryone,
    I work on Opel Astra H 2006 1.7 cdti. The problem on the car is: Dashboard sometimes work perfectly but sometimes is dead total nothing work... then put down positiv and negativ terminal put up again dasbaord works great, the car start every time normaly. And all time when i put ignition the lights front and back of the car goes ON.. Trouble cod in ECU is P0650 no communication with CIM. In other module he has fault code to not comunicating with IPC its normal fault when dashboard is not working. When dashboard working no trouble code. I try to reset UEC and REC module with OP COM and put down negativ terminal for some while than back and its worked for some houre , then again back in thah mode ... I dont know what to do , any idea ?
    Sorry for bad eanglish..
    uk
    may be easier to replace cluster with used one if you dont find the fix..
    Apr 2016
    Quote Originally Posted by raf0468 View Post
    I will try to replace cluster and CIM modul... :/
    Aug 2018
    East Pole
    Quote Originally Posted by milanche View Post
    A known problem is the corrosion at that model. Verify and diamantle the uec, clean it well, put it back. Also, you can verify wiring harness and ecu sockets, or even ecu could be taken water inside...
    Apr 2016
    I cleaned UEC and REC modul.... but nothing , do resolder job on cluster... nothing... i think CIM is the problem..
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    if its cluster problem,then you have to resolder all the parts in the cluster especially the connector.
    you can see if cluster loses its 12v ,find pinout and put a tester lamp there if it has 12v and cluster is off,its cluster issue.If it loses 12v then you go back to where it gets the power.
    If i Helped you,use thanks and rep button to thank me back
