Results 1 to 10 of 10
    Oct 2017
    Default Opel Siemens VDO NCDR 1100 - Virgin dump - Shooting
    I need virgin dump for this car radio, and code for display:
    eeprom: 24C16
    PIN code for display:
    eeprom: 93C46
    WALES
    Quote Originally Posted by blackops021 View Post
    eeprom: 24C16
    eeprom: 93C46
    Display dump read with wrong setting and radio virgin by obd2...
    Radio by dump is complicated way...
    wbr
  3. The Following User Says Thank You to shooting For This Useful Post:
    sonices (11th March, 2020)
    Oct 2017
    Please, can you tell me how can i read with correct settings both dumps?
    Quote Originally Posted by shooting View Post
    wbr
    WALES
    Display should be 93C56 in 8bit
    wbr
    Oct 2017
    Please try now. With this code i can unregister radio by obd2(OP-COM, FVDI)?
    Display should be 93C66 in 8bit
    wbr
    WALES
    PIN is 2094
    wbr
  8. The Following User Says Thank You to shooting For This Useful Post:
    Albert G (11th March, 2020)
  9. #7
    Oct 2017
    Can you tell me how can i pair with display, with this pin? I try activate & deactivate theft protection, but failed...
    PIN is 2094
    wbr
  10. #8
    WALES
    You need to unregister radio from previous car then pair using pin given.
    Or use Full Tech2 to pair
    wbr
  11. #9
    Oct 2017
    I need display from previous car, and i can unregister radio correct? I try unregister this radio from new display(using your PIN) and failed. I tried with OP-COM, Tech 2, FVDI...
    wbr
  12. #10
    WALES
    Needs full Tech2 not china tool... or unregister in old car first.
    Only other way is to change the dumps from all the flashes in the radio
    wbr
  13. The Following User Says Thank You to shooting For This Useful Post:
    irfa (12th March, 2020)
