Hello! I have a problem with the correct removal of the throttle error (P1125) Opel Astra 1.7 cdti, ECU edc16c9.Auto is in safe mode, no power, engine speed only up to 3000 / min. Is anyone able to help?
try this but for proper solution full bdm file is needed
krokodyl30 (13th March, 2020)
Thanks! Unfortunately this file does not work! There is still a control on the board and no power!
ok , try this one , disconnect TVA plug
Try this if you want
It's still not good, none of these files work.
Maybe some of you have any idea?
here try and report
before starting the car remove negative of battery terminal and wait around 5 mins
also unplug egr valve
pass in pm
TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
SPECIALISE IN TUNING DIESEL ENGINES
(DEMON DEVELOPMENT)
IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
krokodyl30 (14th March, 2020)
Unfortunately, this file does not work either.Still P1125 and no power.
Thanks buddy, I'll check it. The damper is definitely damaged. After opening, oil has leaked out. The rack is also damaged in the open position.
Turbine control is functional, this has been ruled out. The problem lies in the throttle.
sorry
but you're stupid
Hi !
I need help with a complete EGR delete of the whole EGR sytem in the ECU-box
( 2007 ) Opel/Vauxhall 1.7 CDTI ( 101 Hp. )
Engine code: Z17DTH
Can you help ?
.....A little more power would also be good if it's possible.
Can you help ?[/QUOTE]
WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
Fileservice
no thanks no pass
