Results 1 to 15 of 15
    McDowell's Avatar
    Feb 2019
    Zamunda
    Default Renault Scenic BCM95 D76F0115GM Read
    Hello mates,
    I have this unit with children security lock in the back fault.
    2ba02e44-ca7d-4de8-b938-dc050a267f42.jpg4aa53671-7dfb-4403-95fa-debe3ab70023.jpge76d3509-f701-42d8-b409-9db21890b108.jpg
    I would like to know how to read Renesas. I have tried with VVDI like v850 UPD7073385. But it doesnt work.
    Maybe with this SMOK wiring? I havenīt tried
    And I am afraid of desolder the MPC put it on the donor one and have the same issue.
    I would like to read it first.
    Anyone? Thanks so much in advance
  2. The Following 3 Users Say Thank You to McDowell For This Useful Post:
    alclot (21st March, 2020), Hayssam1 (22nd January, 2021), Meat-Head (24th March, 2020)
  3. #2
    Dec 2018
    may lack nutrition. lift your foot off the board
    Dec 2018
    может не хватать питания. поднимите ногу с доски
  5. The Following 17 Users Say Thank You to Catalizator For This Useful Post:
    alclot (21st March, 2020), cole_mcs (29th May, 2020), conan981 (8th June, 2020), danielif (13th March, 2025), datapage (17th November, 2023), electronicdeivi (26th January, 2022), Hayssam1 (22nd January, 2021), hellmet (18th March, 2024), hrmotorsport (19th December, 2024), kazikk (14th December, 2020), line44 (5th July, 2020), McDowell (20th March, 2020), mcgywer (30th September, 2024), mgtuning (5th May, 2021), pataroucci (4th July, 2023), peko (4th May, 2023)
  6. #4
    alclot's Avatar
    Melee Island
    Hi mates,
    Which mcu I have to select on smok to read it?
    I can find the reference there is on mcu.
    Thanks a lot
  7. The Following User Says Thank You to alclot For This Useful Post:
  8. #5
    alclot's Avatar
    Melee Island
    Hi mates,
    No one there please?
  9. The Following User Says Thank You to alclot For This Useful Post:
  10. #6
    Meat-Head's Avatar
    Try typing in google the numbers off chip with “mask”
  11. The Following User Says Thank You to Meat-Head For This Useful Post:
    alclot (24th March, 2020)
  12. #7
    Dec 2018
    smok can read the V850? if it is stated, try as an analog of
    D70F3384
  13. The Following User Says Thank You to Catalizator For This Useful Post:
    alclot (25th March, 2020)
  14. #8
    FYI renault immotool will virginise used BCM under "card programing" and as other related functions. All done through obd.
    Not much help if you havn't got Renaultimmotool.
  15. The Following User Says Thank You to albertros For This Useful Post:
  16. #9
    alclot's Avatar
    Melee Island
    Hi mate, the problem is I dont have car here. Do you think I can connect by immotools on bench with it?
    Thanks a lot to all. Big help
    Quote Originally Posted by albertros View Post
  17. #10
    Dec 2018
    I work on a bench with immotools. I’ve assembled a stand where all the necessary blocks are connected
  18. The Following User Says Thank You to Catalizator For This Useful Post:
  19. #11
    alclot's Avatar
    Melee Island
    Hi mates again. I tried by smok with and looks like read semothing but finally nothing and gets this error:
    What do you think?
    Thanks a lot
  20. #12
    Dec 2018
    I do not know how smok works with renesans. can he even read this processor. I work with the original orange5 and I always have a great job. a lot depends on the equipment.
    did you connect to the bdm platform on the board, according to the circuit that I published?
  21. The Following User Says Thank You to Catalizator For This Useful Post:
    alclot (31st March, 2020)
  22. #13
    Dec 2018
    Use this connection directly to the processor. if unsuccessfully raise the reset contact from the board and try reading
  23. The Following 2 Users Say Thank You to Catalizator For This Useful Post:
    alclot (25th March, 2020), mgtuning (5th May, 2021)
  24. #14
    McDowell's Avatar
    Feb 2019
    Zamunda
    Hi mates,
    I have clone by iprog the D76F0115GM now the car doesnīt recognize card and car doesnt start.
    I get error codes
    DF002 COLUMN LOCK
    DF172 CENTRAL CABIN UNIT
    I attache readings done,
    Thanks in advance.
  25. The Following User Says Thank You to McDowell For This Useful Post:
    alclot (13th March, 2025)
  26. #15
    McDowell's Avatar
    Feb 2019
    Zamunda
    nO ONES MATES? please if anyone could help me i d appreciate it
    Quote Originally Posted by McDowell View Post
    Hi mates,
    I get error codes
    DF002 COLUMN LOCK
    Thanks in advance.
