Results 1 to 10 of 10
    May 2017
    Default VW Touran 2003 year change dashboard VDO Siemens - error on dash
    I changed dashboard in Vw Touran from 2003 year. I needed to change it because the orginal was damaged. After I flashed Sec Block file from original dash to new (used) dash car started, but I have got "Error" message in place where should be the odometer value. When I turn off the ignition the odometer shows correct millage, but when I will turn on the ignition I have got still "error" message and when I will turn off the ignition I have correct millage again. And all the time like this. I used Smok X-Can. But with Carprog orginal and with X-tool same story.
    VCSD in 17-Instruments shows this fault: 00003 Control Module 014 Defective
    Orginal (old) dashboard is: VDO Siemens VWZ7Z0C7500866, V1312131, SW 0485, HWF02310, HWA02302, ID - 1T0920860A, 28.04.2003
    New (used) dashboard is: VDO Siemens VWZ7Z0E2322884, V0003000, SW 1012, HW 003, ID - 1T0920862A, production date 16.06.2005
    Is it problem with new (used) cluster? Is it damaged too? Or mayby is it problem with eeprom file? In attached original eeprom file read before write Sec Block file and eeprom file read one more time after write Sec Block file
    Sep 2016
    in attached u can find fixed one keep posted
    May 2017
    but I have got "error" mesage on dashboard with both eeprom files
    kiszka's Avatar
    Quote Originally Posted by kobi2311 View Post
    also give me sector block files
    289792km is
    test file eeprom
    report me
    https://mega.nz/#!5rgDUDDD
    I think it should work ok
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
    May 2017
    km value is: 289795
    here is Sec Block file from orginal (damaged) dashboard which I flashed to new (used) dashboard
    kiszka's Avatar
    km value is: 289795
    sector block is ok
    Reality of life :
    4:Everyone lies
  7. The Following User Says Thank You to kiszka For This Useful Post:
    vari (27th March, 2024)
    May 2017
    and I can see that fuel level sensor does not work too (still shows 0 fuel - with old-damaged cluster it worked good). VCDS shows fault: 00771 - Fuel level Sensor (G) 010 - Open or short to plus
    May 2017
    so only the eeprom file is faulty? why it got messed? I did not tauched it - I flashed only Sec Block file.
    What about fuel sensor level? Should it work too with your eeprom file?
  10. #9
    kiszka's Avatar
    you made more kilometers
    Reality of life :
    4:Everyone lies
  11. #10
    May 2017
    Yes. I did same value as in orginal (damaged) dashboard was. But "error" message appearsed after I flashed Sec Block file and before I adjusted km value to 289795
    With your file fuel sensor level should work too?
