Does anybody have access to the latest CD70 Navi Upgrade Disc.
if its maps, about 5 threads down from this one... or are you after the software disk?
http://www.digital-kaos.co.uk/forums...-2010-a-77552/
Does anybody have language CD ver.2008?
Did you find the 2009-2010 software update disc?
the last software cd made for these was dated 10/2007 is that the one you want?
To check you software level do this:
Press and hold the SETTINGS button until you hear a 'bong' - the unit is now in Testmode.
Press AUDIO 3 or 4 times once in testmode to scroll through screens until you get to SOFTWARE.
Look for the software date - it's in the format 10/10/2007.
You will see from the edited pic that it is a 2005 and therefore needs an update...
CD70/DVD90 software update
I used a genuine CD to do mine that somebody kindly loaned me.. This image is extracted from a torrent and in turn reuploaded to mediafire as a .rar file... Extract the rar and it produces a .nrg file... Use Nero to burn this to a decent quality blank CD at slow speed...
To upgrade to your headunit you must turn the ignition on, remove you audio and maps disks then insert the software CD into the map slot... It will check your current software level and if it can update the HU it will ask if you wish to proceed. The update takes about 5 - 10 mins to complete. Your saved radio stations will be cleared but your saved navi destinations should remain. Once completed the CD will reject itself and quickly reboot the headunit..
DO NOT SWITCH OFF YOUR IGNITION DURING THE UPDATE.
Disclaimer: This software is stored on an external site and your use of it is entirely at your own risk. Digital Kaos and its members are not responsible for any damage caused as a result of software used whether it is from this site or links to external sites.Code:http://www.mediafire.com/?ltwlgmdyqbl
hi nige what updates does this give to the head unit and i i am just double checking that its for a cd70 navi just so i don't brake anything as i am good at that![]()
Downloading the one you posted. I will install it tomorrow and get back here. My current ver. is 04/2007.
Later edit: @caveman_nige: from what I see it's the same version, 04/2007. The size it's the same, 140 MB. Care to post the newest version (10/2007) on the web?
I had the car in service for some repairs, but today I'll definitely try the firmware. I'll get back.![]()
