Page 1 of 3 123 LastLast
Results 1 to 15 of 38
    Mar 2020
    Default Looking for some guidance on Stage 1 BKC EDC16
    I've been getting into Mapping recently and have spent a lot of time on the later version of the ecu, but this seems to be missing many maps that most guides suggest it should have (Drivers Wish for example).
    03G906016CB
    EDC16
    0281011900
    371094
    Also what would the harm be if i flashed a
    VW golf 1.9TDI 105HP 03G906021KH 0281013226 380437
    bin file instead?
    See attached for OLS / modified bin / original.
    Thanks.
    Mar 2012
    France
    Hi, never flash other file not from your ecu if you don't know what you do! You can brick your ecu.
  3. The Following User Says Thank You to stephane76700 For This Useful Post:
    mmartin191 (27th March, 2020)
    Dec 2019
    Europe
    for example Audi A3 1.9 tdi pd 105 hp, with EDC16U1 has several different software versions (5347,5497,7640,.....). And if you try to write other flash memory software version without flashing processor memory , you wont be able to start engine. This isn't easy job!
    Different versions have different map structure and adresses.
    You have mistake in your winols project, I see that you're beginner... do you know what is boost limiter map? X-axis is not MAF value, it is air pressure value (1000 mbar....).
    Dec 2019
    Europe
    Also your boost and boost limiter maps are not good!
    Turbocharger of this engine can't hold 1,45 bar of boost for longer period.Also limiter is lower than your target boost..Why?
    Dec 2019
    Europe
    Torque to Iq map is changed. Why? This is bad activity, avoid doing this. ou can only extend x-axis and calculate iq for higher maf value.
    Jun 2013
    EU
    Becuase he do videotutorial tuning, not use brain to understand what is he doing.
    Dec 2019
    Europe
    Quote Originally Posted by morgano View Post
    Exactly.
    Dangerous for engine.
    Mar 2020
    Look guys, I said that i'm looking for guidance, so don't lay into me too hard, I'm only learning!
    Thanks to those that have helped.
    I'm going to make a few edits.
  10. #9
    Mar 2020
    I've made quite a few amendments, could someone have a look for me please?
    I may look at increasing fueling further, to be on the safe side.
  11. #10
    Dec 2019
    Europe
    Now:
    - boost pressure is good (just maybe you should't change values in 15,20,25 mg)!
    - boost pressure limit better now, but don't change last value of x-axis
    - from my experience it's useless to change x-axis values in iq limit_maf map you canjust recalculate last column(interpolate), or maybe you know better.
  12. The Following User Says Thank You to davorsule For This Useful Post:
  13. #11
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    lambda wrong
    iq bad not good
    turbo wrong all flat percentage
    driver wish not touched
    some maps not touched
    hot and cold start why too much fuel added you can brake camshaft very easy
    you need more to learn about remap and to calculate what are you doing
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  14. #12
    Mar 2020
    Thanks for the recommendations once again davorsule and AVDigitale.
    Quote Originally Posted by AVDigitale View Post
    lambda wrong
    iq bad not good
    AV - A few questions:
    1. Could you point out where the Drivers Wish is? I looked over and over, but couldn't find it anywhere - and i've been unable to find the Damos for it.
    2. What are the other maps that are untouched?
    3. This file was pulled from my ecu, I realised that EGR had been turned and other areas had been altered, but I didn't realise it had other major changes.
    I'll rework from an original so that I know what i've changed.
    Thanks.
  15. #13
    AVDigitale's Avatar
    Apr 2017
    contact me latter
    i send you good tutorial and you will learn
    File Service
  16. The Following User Says Thank You to AVDigitale For This Useful Post:
  17. #14
    Mar 2020
    Thank you very much, really appreciated.
  18. #15
    Dec 2019
    Europe
    Quote Originally Posted by mmartin191 View Post
    Thanks.
    Yes, agree with AVDigitale. Iq, lambda not good.
    you must first learn to find, detect, and read main maps..
