Results 16 to 30 of 38
  1. #16
    Dec 2019
    Europe
    your first DW map is at address= D1A3C, 8x16
  2. #17
    familiozo's Avatar
    Nov 2010
    Bulgaria
    If you need i will upload map pack to find maps easy.
    IF I HELP YOU PUSH THANKS AND REP BUTTON
  3. The Following User Says Thank You to familiozo For This Useful Post:
    davorsule (27th March, 2020)
  4. #18
    Dec 2019
    Europe
    here you can see two of seven dw maps,
    also you can use map packs, but then you will never learn finding map skills
  5. The Following User Says Thank You to davorsule For This Useful Post:
    familiozo (27th March, 2020)
  6. #19
    Dec 2019
    Europe
    Look for some maps in 2D view (winols).
  7. #20
    Mar 2020
    Quote Originally Posted by davorsule View Post
    Thank you for looking, i'll look into it now.
    Quote Originally Posted by familiozo View Post
    That would be great thanks.
  8. #21
    Mar 2020
    Thanks for the Screenshots, I'd seen these before, but the rpm on y axis seemed too high and I haven't seen any maps that didn't have the eprom data directly before them (map editing is very new to me)
  9. #22
    familiozo's Avatar
    Nov 2010
    Bulgaria
    Here is map pack.
  10. The Following 7 Users Say Thank You to familiozo For This Useful Post:
    amme88 (30th March, 2020), costyrzv (18th October, 2021), diags (27th March, 2020), marko6jpt (3rd April, 2020), mattb2059 (25th July, 2023), mmartin191 (27th March, 2020), Neproify (5th November, 2020)
  11. #23
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    here is what you need ok hit thnx and reputation pass in PM!
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  12. The Following 7 Users Say Thank You to AVDigitale For This Useful Post:
    alienxbug (19th January, 2023), amme88 (30th March, 2020), Brumi1 (11th August, 2023), diags (27th March, 2020), mALOzLO (25th November, 2024), mattb2059 (25th July, 2023), mmartin191 (27th March, 2020)
  13. #24
    Mar 2020
    Thanks for the above files.
    I've got a question..
    I'm looking to reverse engineer my Air Fuel Ratio and Maf mg/s to output the Fuel Injection quantity.
    So you can calculate AFR by the following formula -
    Maf (Mg/s) / Fuel Injection quantity (mg) / AFR (your chosen fuel is most efficient at) * 10
    I'll give an example.
    (500(a)/28.78(b))/14.7(c)*10 = 11.8(d)
    Which in my case is the value I want to reverse engineer.
    I want to work out what the value of B is, if I know the values of a, c and d. Something that also might come into play is the rpm... 1750(e)
    It there anyway that I can get calculate the fuel from the AFR / MAF in the same manor?
    (this is probably quite an easy question, but it's late and my brain isn't working)
  14. #25
    Dec 2019
    Europe
    Formula you wrote isn't good method to calculate injection.
  15. #26
    Dec 2019
    Europe
    Must presume and test which AFR value will be the best for engine. Factory adjusted maps are usually the best,
    you could compare, but it depends what you want from engine, in which altitude is engine running mostly and other factors.
    Try about 16,6 - 17,1 at higher maf,rpm valus.
    Then calculate lambda from adjusted afr and at last iq_limit_with maf or map.
    Simply first calculate lambda from adjusted afr and then iq with formula.
    lambda= AFR/14,5 or 14,7?
    lambda=(maf/iq)/14,5
    AFR= maf/iq
    iq= maf/(14,5*lambda)
    I can send you excel table which I made, IF YOU CLICK REPUTATION!
  16. The Following 3 Users Say Thank You to davorsule For This Useful Post:
    aparni198 (31st March, 2020), familiozo (28th March, 2020), mmartin191 (28th March, 2020)
  17. #27
    Mar 2020
    AFR= maf/iq
    Thank you mate! I spent far too long trying to work out what IQ was equal to. I've added them into my excel spreadsheet, so i'm going to have a crack at it later.
  18. The Following User Says Thank You to mmartin191 For This Useful Post:
  19. #28
    Dec 2019
    Europe
    Default lambda_excel_table
    Quote Originally Posted by mmartin191 View Post
    here excel table
  20. The Following 6 Users Say Thank You to davorsule For This Useful Post:
    alienxbug (19th January, 2023), amme88 (30th March, 2020), audi a3 (23rd April, 2020), Brumi1 (11th August, 2023), Jozua (29th March, 2020), marko6jpt (3rd April, 2020)
  21. #29
    Mar 2020
    Many thanks!
  22. #30
    Dec 2019
    Europe
    Many thanks!
    Do you understand calculating lambda and iq from table now?
