Results 1 to 10 of 10
    yahia1908's Avatar
    Default MEDIA NAV Connect diag tool
    Now, how to fix the Connect diag tool in Medianav Evolution using the MICOM config.
    First of all, launch WinCE. For example, using Bootloader, which must first be installed.
    Bootloader Medianav 6.0.3 - 6.0.4
    Bootloader Medianav 7.0.5
    After installation, run WinCE. To do this, write to the NK.bin flash drive from this archiveand MICOM config , insert it into the Medianav turned off, start it, and wait until the desktop appears.
    https://cloud.mail.ru/public/AMt7/wesyzfEpC
    https://cloud.mail.ru/public/DKBW/gSbfhomEf
    https://cloud.mail.ru/public/5hi2/hmFw4e9dF
    https://cloud.mail.ru/public/EPt6/X64LqMmUK
    Now we copy the MICOM config itself to the Storage Card, from where we launch it.
    In MICOM we set all the necessary parameters and save (Enregistrer button).
    Then go to the Tuning tab and write the data to your DSI_config, in the system folder.
  2. The Following 4 Users Say Thank You to yahia1908 For This Useful Post:
    asliyucegsm (12th January, 2025), detailer (1st February, 2022), ouragh (24th March, 2022), soukehal (3rd October, 2024)
  3. #2
    yahia1908's Avatar
    In the Reset ECU tab, click in order buttons as in the photo below.
    Done! The median will reboot and there will be no more Connect diag tool.
    yahia1908's Avatar
    For Medianav (4.0.6) everything will be almost the same. Only need to use other files. ( MICOM Config - for medianav with firmware 4.0.6 )
    After setting and saving all the parameters:
    1. In the "Reset ECU" tab, click the "Start Virgin" button.
    2. In the "Tuning" tab, use the "Write DSI CNF".
    3. In the "Reset ECU" tab of the tab, click the "Stop Virgin" button.
    4. Click the "Enregistrer" button.
    5. And "Reset de l'appareil"
  5. The Following 5 Users Say Thank You to yahia1908 For This Useful Post:
    epicsabi (28th March, 2020), petku (28th March, 2020), RadioChiP (26th March, 2022), sonices (30th March, 2020), TERNOCOD (30th March, 2020)
  6. #4
    Jun 2021
    Hello there!
    I managed to get my hands on two brand new Medianav Evolution headunits.They both display the "System not configured Connect diag tool" message.I managed to configure them using this method but i can't seem to get the navigation app to work.I also observed that i can't set the map code for it.What should i try to do in order to get the navi app up and running?
    lwd11's Avatar
    Jun 2016
    Hi. Do you know how to fix the cleared configuration in mn3 (LAN5800WR0)
  8. #6
    GB
    HI . i have tester solution but not working . my medianav have VERSION 7.0.5 i have installed boot loader sucess . but not LUNCH to win ce . all is ok files nk is ok . i thing need dowgrade my medianav to 6.0.4 . I need files if can help
  9. #7
    Sep 2024
    Hi, thanks for this solution, but I still have one question - can I do it on the bench or unit must be in the car? Thanks!
  10. #8
    Romania
    Hi! I have also a question. I have media nav 2,ver.9.1.1 and i entered in win ce for update the maps. fbl with a missing country map. I copy a map, and it works, but i realized that is old, now i want to delete, but windows ce can not do. It say cannot delet this file. I tried to delete the entire nng folder, but the maps file still can not be deleted. I used total commander to copy/ delete files. Can somebody tell me what is the problem, and how to solve? Thanks.
  11. #9
    Nov 2024
    I have successfully installed boot l loader but winc is not activated by nk.bin file. Pls help
  12. #10
    Nov 2024
    I have downgrade software if require email me
