Hi friends, can someone help me with immo off or ecu pin for that ecu? Audi A4 2.5 V6
EDC15VM+ 0 281 010 493
Do It Yourself is the best way
Hi, PIN is 1759.
traxpalicaru (30th March, 2020)
For VCDS .....01759......
Will write the login incorrect even if it is correct, there is a problem in the dump
Thanks, the pin work but nothing changed, the car not start, the rpm rise up when i crank. I don't know what to do. The cluster now show the mileage "Error". On 25 immo not connecting. The immo key in the cluster are not fliking
Hi, did you attempted to read the pin from the Rb4 cluster?
No, i don't disassembled the cluster, he comes like that with problems.
Well someone tried to read or write dump from the cluster and that s why the cluster is corrupted. Happened to me before
Only tool that would fix the cluster would be carprog, even the clone one. Succes
Yes, the imobilizer is located in the cluster.
The best solution for you is the following :
-give up on idea for immo off because the climate control won t work after
1.you have the pin from ecu and you have 50/50 chances.
2.follow the Ross Tech procedure for immo3 and try to read apt the cluster with vcds afterthat the keys.
3.if you not succeed, buy another cluster from some one who can give you the pin and adapt it to your car problem solved.
I went with 3rd option when I dealed with this type of cluster.![]()
Also go on Abs module and note down the coding because you will loose it
traxpalicaru
Your IMMO status is "OFF". The ECM is not "blocked by the immobilizer" So if your fuel pump is operational and vented, the car should start. Use the chemical "sprey" "starter" to start the engine
traxpalicaru (2nd April, 2020)
