Page 1 of 5 12345 LastLast
Results 1 to 15 of 64
    carradio2001's Avatar
    France
    Default RCD310 / RCD510 Calculator
    Hi to ALL !
    As we know, exist free on the internet UPA script algo for calculate the CODE for RCD310 / RCD510 (know as LOW EU or MID EU) from NEC processor and from eeprom (95128/25C128).
    The NEC processor can be read with NEC reader (a simply interface and a program) which return 16 bytes (32 characters) or with Orange-5 for example or another programmer. Will return 655360 bytes or 1048576 bytes
    The eeprom can be read in-circuit with a lots of programmers.
    If have the both information's (NEC STRING) and (EEPROM file) can now calculated the correct code and check / reset the counter. Without NEC string the code cannot be calculated, also the counter cannot be reset.
    Also for a long time somebody discovered how can be calculate the first 2 digits without NEC STRING and with brute force can be found the others digits (00-99).
    From that script I was inspired and make own software for help ! And not everyone have UPA programmer.
    I give you right now to all and please send me any bug or any suggestions.
    The software is still ~B E T A V E R S I O N~
    It is free for your personal use only.
    You are not allowed to sell it, or redistribute it.
    You are not allowed to disassemble, decompile, or reverse engineer it.
    How it is works ?
    1. Need to input the NEC STRING (manually) or load NEC file (the sw will automatically search the sting)
    2. Load the eeprom file (the sw will automatically search the cripted code and the counter)
    3. If have a paired dumps then can reset the dump, check the dump or enter new code and after that SAVE it ...if you want !
    4. Every-time when have errors or wants to load another dumps will go at FILE / STRING cursor and start again.
    Good luck !
    Carradio2001.
  2. The Following 252 Users Say Thank You to carradio2001 For This Useful Post:
    80vvs (9th August, 2022), a-falcon (11th November, 2021), ABD ERRAHMANE (10th May, 2022), abdigoo2016 (24th May, 2023), abu deab (2nd April, 2020), acomecu (20th April, 2023), Adamdad (23rd August, 2022), ADEL.KSHLAF (18th July, 2023), adel_york (21st July, 2020), Adi202 (22nd August, 2024), Adiadi (19th July, 2022), adygopo (17th February, 2022), aissa09 (31st March, 2020), Albert G (31st March, 2020), alexandr1966 (26th July, 2022), alien007 (31st July, 2022), alle bmw (15th August, 2021), aloula17 (24th April, 2021), amor89 (26th April, 2021), Andrnet (12th November, 2020), Anydraj (22nd September, 2021), apreso (2nd April, 2020), arık (3rd July, 2023), asdfghhh (10th October, 2022), asliyucegsm (30th April, 2020), atilla23 (24th March, 2022), audio (31st March, 2020), auto diag2 (7th April, 2025), autoTkey (10th March, 2021), barto41 (24th January, 2021), bbatman (18th November, 2020), bendzji (13th January, 2022), benlyx (6th July, 2021), benyunes (31st March, 2020), bezdakou (24th March, 2021), Bluueelfer (18th May, 2023), bogege (31st March, 2020), boltik5 (15th April, 2020), bonux (30th August, 2021), borafuz (29th May, 2021), bouchmid (10th May, 2022), BoytsovLx (24th January, 2021), bozlakci40 (24th June, 2022), brane0001 (20th June, 2020), bravel digital (1st May, 2020), budata (20th July, 2020), BUSUIOKPETRU (10th September, 2020), buul (23rd January, 2025), cadaseda (1st April, 2020), camel131 (31st March, 2020), catalinosonesti (31st March, 2020), catastefan (31st March, 2020), celil (11th October, 2024), cellakos (5th May, 2020), codigo2 (2nd April, 2022), coke (11th September, 2021), cole_mcs (26th November, 2020), Concord (11th August, 2024), Crasftsman (31st March, 2020), credoline (15th April, 2021), criollo (31st March, 2020), cristinuz (1st April, 2020), damian475 (13th April, 2020), damil (4th July, 2021), daniel53 (17th June, 2021), danielif (26th May, 2021), daniersms (31st March, 2020), Darek90 (31st March, 2020), Decode Ghost (8th April, 2020), dekoderi (20th July, 2020), Dekster (31st March, 2020), delicsapna (14th August, 2022), diaz38 (31st March, 2020), djamel30 (29th November, 2020), Domi (24th January, 2021), dorcky (5th May, 2020), Dr Alex (1st September, 2022), dragan68 (24th June, 2022), Dragan78 (30th April, 2020), dvb_gsm (30th April, 2022), dxyk (15th November, 2021), Edin33 (20th July, 2022), electrod06 (26th April, 2024), elektronik25 (31st March, 2020), elservis (4th April, 2021), eprst (27th January, 2022), Faza0 (1st April, 2020), Firewinx (11th August, 2022), Flekous (14th May, 2021), florin_leo (2nd April, 2020), foulou0238 (15th July, 2022), foxdata (31st January, 2023), fule0000 (15th March, 2021), fww1 (2nd April, 2022), gabriel pablo (6th May, 2020), gecibogar (23rd January, 2021), gen (31st January, 2025), george1 (7th October, 2022), giary74 (20th October, 2022), girolamodisidisi (20th July, 2020), gobe (14th August, 2020), golo (31st March, 2020), Gppetunning (17th January, 2021), guneymemo (1st October, 2022), Hashim1 (10th October, 2024), Hayssam1 (12th January, 2025), hbalazs (1st May, 2020), honel1 (31st October, 2024), hp7909 (23rd March, 2023), hrsuz (27th June, 2022), iliyasergeevich (6th June, 2021), illestibor (24th January, 2022), irfa (31st March, 2020), irodum (2nd June, 2021), Jagupop (11th November, 2023), jaro1801 (13th December, 2021), jcgabbi (27th April, 2020), jemarion2 (30th November, 2020), JHDSoft (1st August, 2023), johanbazelli (2nd March, 2022), Jozua (17th June, 2020), julo45 (12th January, 2021), KacperT (14th April, 2023), kadi0209 (8th July, 2020), kalmar123 (3rd January, 2022), kamel2003 (30th April, 2020), kappa1 (31st March, 2020), kaziukas1958 (30th December, 2022), kazoula55 (17th February, 2023), kolt (19th August, 2022), koshavova (31st March, 2020), lader73 (13th November, 2024), laurentiudania (30th March, 2022), lechus111 (2nd April, 2020), liri (24th November, 2021), luchin9669930 (25th November, 2021), lumetan (19th December, 2021), lupu_sandu (20th January, 2021), lwd11 (31st March, 2020), m3touk85 (2nd April, 2020), MAGHRIBI81 (24th January, 2023), mariantv (8th June, 2020), marina_rv (1st April, 2020), marius7593 (10th February, 2025), martin292009 (31st March, 2020), masteroto01 (16th June, 2022), masterskay62 (31st March, 2020), matrix1975 (8th April, 2020), mclaran (14th July, 2022), mcm44 (29th July, 2022), Menber (22nd January, 2021), mete38 (4th November, 2020), mevlid89 (10th June, 2021), mickye_dj (14th September, 2023), mikroel (31st March, 2020), mimodiag (31st March, 2020), mio1706 (16th May, 2020), mohamad1401 (31st March, 2020), mohamed_dz (11th April, 2020), moldo25 (6th March, 2025), molekula (28th January, 2025), molnariuliu (27th March, 2023), momogsm (20th July, 2020), murat332 (1st April, 2020), m_yura (13th August, 2020), nabilyas8472 (15th April, 2022), naprawa5 (31st March, 2020), nebil hizaoui (21st April, 2020), neksus (22nd March, 2023), nelutzul40 (1st April, 2020), nenadgorgi (31st March, 2020), neverseenpotato (31st March, 2020), nigrou (31st March, 2020), nihadbeg (19th April, 2020), NONO59 (22nd July, 2024), orionian (13th November, 2024), ouragh (5th November, 2020), ozdentv (5th May, 2023), papaone (9th March, 2023), Papiti56 (6th October, 2023), paradajz (1st May, 2020), pedjica (8th December, 2020), peliquito (31st March, 2020), Pocok81 (13th June, 2021), powerelectricpl (1st September, 2023), raductn (11th January, 2022), rafhic (3rd May, 2020), Rampwow (8th July, 2024), ranzoo2020 (22nd November, 2021), ravcas (31st March, 2020), rch11 (11th January, 2021), Rebello Brian (9th September, 2020), RedNix (1st April, 2020), REZON (31st March, 2020), Robert34 (31st March, 2020), sandocan75 (23rd July, 2021), sanjap (12th September, 2021), sathex (31st May, 2021), sebarod10 (9th February, 2022), semsem (16th June, 2020), senanlat (1st April, 2020), sepistar (1st September, 2021), serg777 (13th March, 2021), ShineHunter (20th August, 2021), shooting (31st March, 2020), sidj (1st April, 2020), Silver740 (25th April, 2022), simiszer (26th June, 2022), Sky3Pro (23rd January, 2021), slav77 (22nd July, 2020), slavi1 (1st April, 2020), smoggy (31st March, 2020), socha1997 (16th June, 2020), sonices (31st March, 2020), soukehal (30th July, 2023), stefaudio (14th April, 2020), strbr (24th January, 2024), Supas (4th February, 2022), svetlim (5th May, 2020), tawaf111 (16th December, 2023), Tecdiag (20th September, 2020), telekomm (14th June, 2022), TERNOCOD (14th April, 2020), toyota123 (10th January, 2021), unique user (15th December, 2021), VenomUA (5th August, 2024), vlad33 (15th August, 2021), vorovei constantin (11th January, 2021), vovamercedes76 (14th January, 2024), xXxtadej (1st May, 2020), yahia1908 (31st March, 2020), yilmazlar (8th April, 2025), zappaf (22nd December, 2020), zrr_immo (1st April, 2020)
  3. #2
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    great work ,alll for free ,
    best regrads
  4. The Following 9 Users Say Thank You to catalinosonesti For This Useful Post:
    carradio2001 (24th January, 2021), damil (24th January, 2022), gamsahurd (10th January, 2021), jaro1801 (13th December, 2021), karim72 (30th January, 2021), m3touk85 (2nd April, 2020), matrix1975 (8th April, 2020), mevlid89 (10th June, 2021), MrRepair (5th May, 2020)
  5. #3
    Jul 2011
    thank you good partage
  6. The Following User Says Thank You to mimodiag For This Useful Post:
  7. #4
    mohamad1401's Avatar
    Dec 2010
    DK
    thank you ......
  8. The Following 2 Users Say Thank You to mohamad1401 For This Useful Post:
    aissa09 (31st March, 2020), carradio2001 (24th January, 2021)
  9. #5
    Raimax's Avatar
    Nov 2013
    LT
    Quote Originally Posted by carradio2001 View Post
    Hi to ALL !
    How it is works ?
    Good luck !
    Carradio2001.
    Good job but there are mistakes
    Counter is on B48h:
    Counter 0 or 1 or 2 always a different byte
    Blocking is on B44h:
    Counter 0 or 1 the data byte does not change
    Counter 2 the byte is changing
    I think I wrote it understandably
    If you don't like it * close your eyes
    --- Geros dienos ! ---
  10. The Following User Says Thank You to Raimax For This Useful Post:
  11. #6
    Jan 2012
    Nec reader not save ".bin"
  12. #7
    France
    Quote Originally Posted by RadioChiP View Post
    You can rename it or enter manually the all 32 characters. The software load only .bin files
  13. #8
    Apr 2013
    RO-IS
  14. #9
    Dec 2018
    thank you verry much
  15. The Following User Says Thank You to Manole321 For This Useful Post:
  16. #10
    France
    Quote Originally Posted by Raimax View Post
    Counter is on B48h:
    I ask for more information's on another topic.
    From my all paired dumps I found these situations:
    SAFE count1 = 535353
    SAFE count2 = 626262
    SAFE count1 = 4B4B4B
    SAFE count2 = 000000
    SAFE count1 = 313131
    SAFE count2 = 313131
    SAFE count1 = 000000
    Of course the SAFE can be SAFE 0, SAFE 1 and SAFE 2. (These are 3 situations, I found 5 situations).
    If somebody explain me how exactly as it work ... I will update !
    Carradio2001.
  17. The Following User Says Thank You to carradio2001 For This Useful Post:
  18. #11
    Raimax's Avatar
    Nov 2013
    LT
    SAFE count1:
    For SAFE 0 and SAFE 1 can be 31 or 7A or 4B
    For SAFE 2 can be 53 or 18 or 29
  19. The Following 13 Users Say Thank You to Raimax For This Useful Post:
    Bllinda (2nd April, 2020), bogege (1st April, 2020), boltik5 (15th April, 2020), branco (1st April, 2020), bronec10 (15th August, 2020), canisha (9th January, 2022), carradio2001 (31st March, 2020), catastefan (1st April, 2020), Hayssam1 (12th January, 2025), lwd11 (2nd April, 2020), masterskay62 (1st April, 2020), razvanrms (1st April, 2020), shooting (1st April, 2020)
  20. #12
    Aug 2015
    Argentina
    Hi to ALL !
    How it is works ?
    Good luck !
    Carradio2001.
  21. The Following User Says Thank You to apreso For This Useful Post:
  22. #13
    Aug 2010
    Great work!
    Thank you!
  23. The Following User Says Thank You to Dragan78 For This Useful Post:
    carradio2001 (1st May, 2020)
  24. #14
    bravel digital's Avatar
    May 2014
    morocco
    thank you verry much good partage
  25. The Following User Says Thank You to bravel digital For This Useful Post:
  26. #15
    Aug 2016
    Thank you very much for your great contribution. regards
  27. The Following User Says Thank You to dardoelectro For This Useful Post:
    carradio2001 (14th August, 2020)
