Results 1 to 11 of 11
    everywhere
    Default EGR OFF DTC OFF Iaw 4mv VW POLO
    Hello
    can anyone do correct egr off file in IAW4.MV? I tried to do dtc off but after 50-100km i have fault codes again... P0401 P0402 P0403 P0420 P1403
    Thanks a lot, best regards
    Mar 2013
    poland
    Default egr.off
    try and report
    pass in pm
  3. The Following User Says Thank You to mmomotiuk For This Useful Post:
    piemot (8th April, 2020)
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Quote Originally Posted by piemot View Post
    Hello
    P0420 is about faulty catalyst...
    everywhere
    Quote Originally Posted by bobolin4o View Post
    yes i know my friend. thats why i posted egr off and dtc off. Dtc from catalyst :-)
    dehacko's Avatar
    Feb 2018
    SK
    Please whitch tool you doin read/write?
    bobolin4o's Avatar
    Quote Originally Posted by dehacko View Post
    Kess, FG54...
    dehacko's Avatar
    Feb 2018
    SK
    kess clone is possible? checksum is correct?
    bobolin4o's Avatar
    Yes, but in some cases the coding of the ECU changes, so first you must check it with VCDS and save it, and code after flashing.
    With FG no such problem.
    Some of ECUs didn't allow OBD read/write...
  10. #9
    everywhere
    yes, coding is different after flashing. I read/write with kess v2 no problem. Bobolin4o have you got solution for egr off?
  11. #10
    Member YougNord's Avatar
    Apr 2020
    you will get many probleme with this ecu
  12. #11
    bobolin4o's Avatar
    Maybe, depends of what is the problem...
