Results 1 to 12 of 12
    Sep 2014
    Somewhere
    Default VW Crafter 2.0 EDC17C54 DPF off needed
    Hi to all!
    I need good DPF off for an Vw crafter year 2012, engine 2.0 CKT, KW80, ecu EDC17C54.
    ECU ID ECU 03L906012Q
    0281017789
    HW H23
    Ecu is read by KTAG in boot.
    PS: I must disconnect sensors? Before write I must reset DPF values?
    Thanks!
    Newmotors's Avatar
    May 2019
    brazil
    100% solution leave everthing on just make do DPF DELET exhaust
  3. The Following 2 Users Say Thank You to Newmotors For This Useful Post:
    diags (6th April, 2020), Jashmine1983 (6th April, 2020)
    Newmotors's Avatar
    May 2019
    brazil
    reported + thanks please
    Sep 2014
    Somewhere
    Quote Originally Posted by Newmotors View Post
    Hi!
    The car starts and DPF lamp from instrument cluster is off.
    But the car does not rev over 2500 RPM and the engine light and the spark plug lights are flashing on instrument cluster, when the engine is running.
    On ignition only thew spark plug lamp is flashing.
    After scan I have only the cooler pump B circuit DTC (That was before and the car was running good).
    Newmotors's Avatar
    May 2019
    brazil
    you have a problem with an eletric water pump....
    this happens a lot and the car ties it up even send me the dtc code to delete it
    CHECK IF the dtc is p261a
    Sep 2014
    Somewhere
    I'll check tomorrow...but with this code the car was driving fine until the DPF light come on.
    I've tried to delete it but the DTC appears instantly.
    Newmotors's Avatar
    May 2019
    brazil
    there's nothing to do with the other friend, i can guarantee you
    already used this solution for 7397393003
    prevozsa's Avatar
    Mar 2015
    Bosnia
    Default try and report
    your file after tnx and reputation pass
  10. The Following User Says Thank You to prevozsa For This Useful Post:
    Jashmine1983 (9th April, 2020)
  11. #9
    Sep 2014
    Somewhere
    Before I had P261A DTC.
    I've replaced the water pump, but now I have the P261C 00 (167) Coolant pump 2 short to GND, and the car does not rev. I've cleared it with scanner, but the P261C DTC reapear and engine light and spark plug lights are flashing and the car does not go over 2500 RPM
  12. #10
    Sep 2014
    Somewhere
    Hi to all!
    I still need good DPF off and DTC's P261C and P261A deleted.
    Thanks!
  13. #11
    Baddog84's Avatar
    Sep 2012
    Germany
    your file dpf and dtc off
    chks by tool
    pass pm
    Quote Originally Posted by Jashmine1983 View Post
    Hi to all!
    Thanks!
    WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
    Fileservice
    no thanks no pass
  14. The Following 3 Users Say Thank You to Baddog84 For This Useful Post:
    diags (12th April, 2020), Jashmine1983 (11th April, 2020), Newmotors (2nd June, 2020)
  15. #12
    Sep 2014
    Somewhere
    Quote Originally Posted by Baddog84 View Post
    chks by tool
    pass pm
    Thanks! Your file works good.
