Results 1 to 11 of 11
    Oct 2014
    Default V W RADIO LOW EU BVX
    Hi, can some one help me with radio code please on this Blaupunkt VW Radio Low EU BVX. The eeprom is a 95128. Many thanks for any help.
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    Quote Originally Posted by MUTTLEY NAGS View Post
    yes this is eprom ,but for fulll code must read also NEC procesor
    wbr
  3. The Following User Says Thank You to catalinosonesti For This Useful Post:
    masterskay62 (7th April, 2020)
    Oct 2014
    Default radio code file attachment
    attached find the radio code file
    Mar 2019
    east nord pole
    with this file i can help you with first 2 digit s ,but not here put in the corekt post
    WALES
    Need to post dump from NEC processor too for code
    wbr
    Mar 2019
    east nord pole
    write this dump in your 95128 st then power on the radio ,after read again post new dump and i give first 2 digit s
    wbr
    Oct 2014
    Hi, would anyone have BDM pinout points on board for reading NEC D70F3358 please. Many thanks
    May 2018
    https://www.digital-kaos.co.uk/forum...ghlight=rcd310
  10. #9
    Oct 2014
    Hi, here is the dump file 95128 with radio powered on. Many thanks for your help
  11. #10
    Mar 2019
    east nord pole
    Write my dump i s modify dump, then Power up radio, nec MCU will write New dump, then post and you can get first 2 digitis
    After must try the Last 2 DIGITS.
    Wbr
  12. #11
    Mar 2019
    east nord pole
    hy ,you make the corect procedure ,your code start with 08xx ,after 2 try you see safe mode ,must reset .
    here you can read ,is wery helpfull for you ,if not read NEC to get full code
    https://www.digital-kaos.co.uk/forum...hlight=digitis
    wbr
