Results 1 to 9 of 9
    Aug 2018
    Default Astra BCM GlobalTis failure
    Using GlobalTis SPS whilst trying to reprogram virgin BCM to 2012 Astra J
    E2700: Hardware Mismatch
    No programming possible
    Hardware Number 13504847
    The software we have is 2011/12, the vehicle is 2011/12. Could this be due to software slightly out of date?
    Dec 2018
    GB
    Possible hardware differences bcm opel and vauxhall. Globaltis is dedicated to opel.
    Example opel speedometer km , vauxhall speedometer mile ,opel commands left door ,vauxhall commands right door , steering wheel ,etc
    Aug 2018
    Maybe try OPEL option?
    Dec 2018
    GB
    Check the hardware version from the old BCM. If it's not identical I don't think it works. Try the Opel option but I think it won't work. If you do not go looking for a bcm with the hardware version identical to that of the old BCM . I'm waiting for the message to see what you've solved. Successful!
    Aug 2018
    Old and New BCM have same numbers.
    Dec 2018
    GB
    Try a Vauxhall dealer, there is SPS online. Another option I don't know. Have a good day.
    Aug 2018
    I think i have it sorted. Will update shortly.
    Aug 2019
    Bulgaria
    WIN numbers must be changed. Abrites, IO terminal....
    Then program with GlobalTis SPS.
    Aug 2018
    So, I have configured BCM, gets as far as brake pressure sensor learn and then fails.
    Radio now works and cluster displays correct odometer.
    Cannot program keys.
    Current ECU Software 13504847
    Select ECU Software 10002922
