Results 1 to 15 of 18
    Oct 2018
    Default Passat B7 keyless ID46 problem
    Hello
    A customer came yesterday with a Passat B7 2012 , keyless ID46 to make a second key for the car. The keyless function worked , car started with the key in my pocket by pressing START button next to the gear lever.
    I opened the CCM , 3AA959799 so I can read the eeprom to find the pin and cs bytes . I desoldered the eeprom from the board read it and put it back.
    After I put everything back, the car started but I couldn't learn the dealer key I made with VVDI2. After that I pressed the Learn Keys button and the car displayed 0-2 on the dashboard and " Immobilizer adjustment active" . I took the key (original key ) from the contact and inserted it again to learn it but an error occurred " Immobilizer error " and it wouldn't learn it .
    I reopened the CCM and wrote the original eeprom dump. The car could start but only if I inserted it in the contact. Also the remote function of the key doesn't work anymore.
    I tried again to learn the keys but the same problem " Immobilizer error " . Then I tried to add second key directly to the eeprom dump using TM100 and writing the generated dump. Now the car would't start with the original key , displaying " Immobilizer active ". Every time I performed the learning procedure the second key was outside the vehicle
    Finally I wrote the original dump and the car can start with the original key, but there is the problem with keyless and remote function.
    The customer told me that he had a similar problem a couple of months ago with the keyless system , the car only started by putting the key in the contact. He said the remote always worked.
    I suspected there was a problem with the key battery and changed it but didn't solved anything
    I attached the eeprom dumps , eeprom-1 is the original dump I read , the one that the car can start now without keyless function.
    Second dump eeprom-2 is the one that CCM modifies every time I perform the Learn Keys procedure.
    Can anyone check the dumps , I suspect that maybe the first time I read the eeprom it got corrupted and caused all the problems.
    Any advises and ideas are appreciated.
    autodiagservices's Avatar
    Firstly, do you have VCDS ? try and program the remote fob via the central convenience.
    super jumbe's Avatar
    Livingstone
    Quote Originally Posted by autodiagservices View Post
    You can not programme remote when car does not satart, have tried disconecting battery trick?
    Oct 2018
    The car starts now , but only by inserting the key in the ignition , not using the keyless function
    I tried to program the remote using Launch and it didnt let me go through
    From what i understand on ID46 models the remote is programmed the same time you learn the key.
    Channel 001: Remote Control Matching
    • Start Matching new/additional Remote Controls with entering 1, then Test and Save the New Value.
    • Press the Unlock button on each Remote Control you want to add, the Blinkers will light up to confirm the Adaptation Process of each Remote Control.
    Note: The time for matching remotes after saving the new value should not exceed 15 seconds. You can add a maximum of 4 remotes. Remote Control for Cars equipped with Keyless Entry and Access are automatically being matched when Adapting the Immobilizer/Keys.
    igorr's Avatar
    Aug 2010
    Your second key is bad, write ori dump back and Then learn old key again and remote will work again. There is no separate learning remote control
  6. The Following User Says Thank You to igorr For This Useful Post:
    immoneard (15th April, 2020)
    Oct 2018
    I didn't get to learning the second key. After I start the learning procedure the car gets into learning mode " Immobilizer adjustment active " , displays 0-2 , I take out the key and put it back again , the car should learn the key and display 1-2. Instead it gives the error . This is with the original key
    rola1971's Avatar
    Jun 2014
    Dublin
    this no need write dump
    you read and you have cs and pin from ccm
    make dealer key
    after vcds programming this key
    but key need full new ,no posibility change only 7936 it is need full new
    i make passat and passat cc this key
  9. The Following User Says Thank You to rola1971 For This Useful Post:
  10. #8
    Oct 2016
    Slovakia
    Try to use it Immo data tool
    Dump ee2 - keys inactive
    Number of Keys: 2
    Id48/Id46 A - Id46 B
    Key1: inactive 4E9F3614 - 0E324606
    Key2: inactive A5C5EE14 - 0EE924C4
  11. #9
    Livingstone
    Make dealer key with this info and programme new key which tool you are using?
    VW PASSAT 2012 B6 (B7) HITAG
    PIN: 55180
    IMMO: VWZCZ000000000
    VIN: WVWZZZ3CZBP303224
    CS: 23 4D 78 B2 15 70 74
    PCF: 7936 / 7936
    EEPROM: 95320
  12. #10
    Oct 2018
    Quote Originally Posted by super jumbe View Post
    PIN: 55180
    PCF: 7936 / 7936
    EEPROM: 95320
    That's what I did , using VVDI2 .
    The problem is that when I try to learn the keys the ccm locks itself . I can't even learn the original key .
    I also tried to learn the original key by VCDS and no luck.
    The only way to make the car start again is to write the original dump back. But the keyless function and remote doesn't work
  13. #11
    Aug 2018
    East Pole
    ODIS will solve it
  14. #12
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    When you returned old dump,you only returned key to CCM module,but not in Kessy module.
    After you learn keys via OBD,Keyless function will return.
    I would suggest reading the DTC's because playing with dumps isnt going to get you anywhere.
  15. The Following 3 Users Say Thank You to simaservis1108 For This Useful Post:
    immoneard (15th April, 2020), p1et (15th April, 2020), ricked (15th April, 2020)
  16. #13
    Oct 2018
    I understand that.
    The problem is I can't learn the keys by obd.
    I get stuck after performing the adaptation on channel 01.
    Are there any tricks regarding the ID46 system ?
    After I perform the adaptation I remove the key from the ignition and put it back again. It won't learn it and still displays 0-2
  17. #14
    Oct 2016
    Slovakia
    Quote Originally Posted by volorucinski View Post
    ODIS will solve it
    ODIS offline ?
  18. #15
    Jul 2019
    Quote Originally Posted by cosmynnec View Post
    I understand that.
    You can not have 0-2,0-2 is to program 2 keys and if second key is not good then you will get locked out , you need to have 0-1 , choose only one key to program , then pull key out and put back , and wait till show 1-1, then pull key out and put back again.
