Page 4 of 15 FirstFirst 12345678914 ... LastLast
Results 46 to 60 of 219
  1. #46
    Mar 2021
    Thank you Fantomel.
    I was able to download a text file.
    I'm Happy!
  2. The Following User Says Thank You to xJlaIIax For This Useful Post:
    metaleks (27th December, 2021)
  3. #47
    Apr 2009
    Thank you Fantomel !!!
    Great job ...
  4. #48
    fantomel's Avatar
    Mar 2009
    Us
    Quote Originally Posted by soul87 View Post
    Hi, fantomel Thank You very much for this
    It works with my v5 cable but I have a question
    I have a windows 10 64bit and I found that all versions have a bug, when You start to record live data from measuring blocks program will automaticaly close after 5-10seconds of logging, is there any chance to fix it ???
    Inside op-com folder apart from op-com exe you have also LogFileViewer.exe. This file is responsable for live data. Try and put it in compatibility mode and maybe will do the job.
    If you like my post and it helped you please press THANKS.
  5. The Following 6 Users Say Thank You to fantomel For This Useful Post:
    bar7212345 (25th October, 2021), Gurbettekises (7th February, 2022), jgdf (3rd September, 2023), npocmaka (1st May, 2021), torzet (21st December, 2021), volodin69 (20th July, 2021)
  6. #49
    Apr 2021
    Cześć,
    Przyjaciele, mam op-com jak poniżej ze zdjęć.
    Chciałem zapytać, czy mam odpowiednie urządzenie do konwersji.
    W tej chwili działa u mnie program VAUX-COM_120309a + 160115a
    Obsługuje samochody do 2016 roku.
    Czy mogę skorzystać z przewodnika przyjaciela Fantomela? Jak ktoś może mnie dokładnie pokierować, jak to zrobić?
    Pozdrowienia
  7. The Following User Says Thank You to Lacrooix For This Useful Post:
  8. #50
    Dec 2014
    PL
    Your interface looks like a good Opcom V5. Read "how to use". Install Fantomel software and enjoy.
  9. The Following 9 Users Say Thank You to Mario6 For This Useful Post:
    Gurbettekises (7th February, 2022), jusna (12th March, 2023), kastissu (25th February, 2022), metaleks (16th January, 2022), okm (16th July, 2023), omarzoro (28th May, 2021), Sanyamaci (1st April, 2023), Shan (11th September, 2024), stiloboro (8th April, 2022)
  10. #51
    Apr 2021
    I installed the software: OP-COM_200603a_EN_Pro_v20830_Free4All
    The interface itself has updated to version V01.67
    But the problem is that it is not related to the car.
    Do I have to do anything after installing the Fantomel program? Any exact instruction? I will be grateful.
    USB FTDI 2.8.30.0 drivers are correct?
    Thank you very much in advance for your help. greetings
  11. The Following User Says Thank You to Lacrooix For This Useful Post:
  12. #52
    Oct 2011
    Croatia
  13. #53
    May 2021
    Thank you Fantomel!
    I was able to get the v5 adapter from Ali Express and it updated fine. The only issue is that when programming it gives a "this function is not available" error.
    I have tried all the attached versions on windows 7 64bit. It identifies my zafira-b 2013 but no luck trying to enable cruise control.
  14. #54
    May 2021
    Latviа
    Thank you for the information. I redone my OPCOM NEW, CH-CAN works ,except version 2006003.
  15. #55
    Feb 2019
  16. #56
    Newbie sopido's Avatar
    Feb 2018
    Hello everyone!
    Is this a good one?
  17. #57
    May 2021
    thank you very much for your work
  18. #58
    May 2021
    Thanks for your sharing
  19. #59
    fantomel's Avatar
    Mar 2009
    Us
    @sopido Fake pic chip.
  20. #60
    Jun 2021
    Great job ...
