Results 1 to 15 of 17
    Sep 2019
    Croatia
    Default EDC16CP34 - 4.4 flash counter reset
    hi,
    please help VW Crafter 2.5 tdi CR edc16cp34 - 4.4 flash counter reset to zero
    thx
    Jun 2013
    EU
    Saying actual counter values would help.
  3. The Following User Says Thank You to morgano For This Useful Post:
    NStuning (4th May, 2020)
    Sep 2019
    Croatia
    Quote Originally Posted by morgano View Post
    Flash Attempts: 8 Times
    Flash Programmed: 6 Times
    Kess says "Wrong security code"
    KTAG write FULL BDM with complete Restore okey and car start..if I write only Flash file the car doesn't start. I write FULL BDM again from the first file the car works again.
    Shmortz's Avatar
    in the middle of nowhere
    did you try to reset counter with KESS using option? what KESS version do you use?
    Sep 2019
    Croatia
    Quote Originally Posted by Shmortz View Post
    Yes, the "Wrong security code" always appears. Kess EU clone v2.23.
    Shmortz's Avatar
    try using newer version, last working is 2.53
    Sep 2019
    Croatia
    Resolved Counter reset but I still have the same problem...Thought this would solve my problem.
    Galletto through OBD says "ECU locked"
    I've never had anything like this before.
    Sep 2019
    Croatia
    Yes I did, it's the same.
  10. #9
    Shmortz's Avatar
    Quote Originally Posted by NStuning View Post
    is there any modifications in flash, maybe it is locked for OBD reading?
  11. #10
    Sep 2019
    Croatia
    I have this one, it's the original I read with OBD at the beginning before locking after few writing in the reworked files.
  12. #11
    Shmortz's Avatar
    what tool did you yse to read it, i have same version i tbink one read with Galetto 54, other maybe with kess, in your dump there is nothing before $180000, one of mine is exactly same, but in the other data is starting from $40000, here is my dump to compare
  13. #12
    Sep 2019
    Croatia
    KESS v2.23...and everything was fine a few times...reading and writing over OBD
  14. #13
    Shmortz's Avatar
    maybe you can try find full BDM, make off in eeprom and try, I have one kit from same ECU if you want
  15. #14
    Sep 2019
    Croatia
    I have some full BDM form here from forum...but eeprom is not the same so it won't work, right? Can I just insert my eeprom instead of that eeprom and leave the other files? Or I can use IMMO Universal Decoding v3.2 is this software OK for that? Because I have to write everything together, when I write a single Flash file, the car does not want to start (no heater lamp and no turning then). When I write everything together with the first file, the car works again.
    p.s. yes as you say make off... I can use IMMO Universal Decoding v3.2 is this software OK for that?
  16. #15
    Sep 2019
    Croatia
    Can you please help me with immo off? I tried with immoo universale 3.2 and immo service tool v 1.2 and no luck
