Hi, probably someone switched polarity on battery charger in the car and immobox and ecu exploded some components.
I got a new (used) immo box and cloned 93c66 fine, so that should be all good with the transponder.
Now I also have a new (used) ECU but don't have any memory I can clone and car does not have 16 pin obd2 connector to sync. It has a 23 pin connector under the hood.
immo box part number: 89780-60040
ecu part number: 89661-60540
So, how can I make the new(used) ECU from other car work in this car?
regards
