Hi keep getting code p228c.
Relates to fuel pressure regulator have changed fuel filter still getting same and limp mode can someone tell me location of the regulator please.
Its a transit custom euro 6 2.0
Look on eBay at dirty pictures
Not convinced theres 2 one in pump and mechanical in rail
Meat-Head , I'm just trying to help. is what it is about in the forum. At least what I think about. I asked to upload a photo of the fuel pump to tell you what it is.
Enviado desde mi SM-G973F mediante Tapatalk
this is the fuel pressure regulator .. with forscan you have to adjust the injection and adjust the regulator. and made several with forscan. what's the problem with the car.
Jamaly (9th May, 2020)
Car engine was making noise was told bottom bearing sent to it to a recon company that quated me 1900 for full rebuild ended up charging me over 4k and returned car with loads of fualts said he couldn't code injectors which he replaced which ive done but still in limp
Comes up with p228c codes
I cant find anything to do with regulator in forscan i also have ford ids
what year is the transit? until version 2014 and performed these functions with forscan
Hi its a 2016 2.0 130ps
if it doesn't appear in forscan you need ids
the fuel pressure regulator has no adaptation.
If the problem persists, there can only be two situations, one or the pump was not at the point of distribution despite being a chain or belt, or the pump is damaged or damaged by starting the engine ....
you can take a picture on the engine adaptation functions for me to see, thanks.
