Results 1 to 3 of 3
    Sep 2008
    Default Citroen Nemo maf sensor error codes 010400 P0104
    Hi Gents, the engine management light has come on.
    I have read the error codes with wow wurth.
    Trouble code: 010400
    Trouble code: P0104 mass or volume air flow "A" circuit intermittent /erratic
    Does anyone have the pinout for the MAF sensor connector? So I can check for faults in wiring, before buying a maf sensor.
    What is error 010400?
    Finally, P9010 brake pedal switch, but all brake lights are working.
    It's a DV4TED 1.4hdi 2009 year.
    I've googled but can't find any definitive info, diagrams etc.
    Your help would be appreciated, thanks in advance.
    cotymoto's Avatar
    May 2009
    Because it has a 4-pin switch 2 for kuces and 2 to inform the motor ecu that you are stepping on the brake. It is a typical failure.
    Enviado desde mi SM-G973F mediante Tapatalk
    Sep 2008
    Thank you Cotymoto for brake switch info.
    Do you have any information for MAF sensor errors P0104 & 010400?
