Results 1 to 9 of 9
    Default Volvo V50 1.6 EDC16C34 - Error Code 7700
    Volvo V50 1.6 with ECU 0281011775
    Car has error Engine ECU 7700 seems like a checksum error or ECU error.
    Then also ABS error 0101 no communication with engine ECU
    Engine light is OFF, Anti squid light is ON and message on dash.
    This problem seems usual on these cars but canīt understand how to solve it.
    I bought another used ECU, cloned it and the problem is the same.
    Then I saw a Flash file here on DK very different than my file for the same ECU.
    So, I write this file and test on car. Exactly same problem.
    Someone has a solution for this ?
    Attached Flash ORI + eeprom ORI + Flash file I tried from forum.
    Thanks for your help
    rafal's Avatar
    UK - PL
    is it dpf on or off ?
    need help
    now my goal is to buy xp-005
    who will help?
    Its stock. EGR and DPF working normally.
    But if you want to remove please do it.
  4. The Following User Says Thank You to aqua_life For This Useful Post:
    acam712 (26th August, 2020)
    May 2020
    tot557545@gmail.com
    aqua_life
    hi help you error dtc code off no light dasch..........
    rep and thnx button for help good day
  6. The Following 4 Users Say Thank You to ecuprogramer For This Useful Post:
    aqua_life (22nd May, 2020), luxervol2 (10th December, 2021), Mxbike (19th December, 2020), zzappy (12th May, 2022)
    Jul 2019
    Italy
    hi can i have password plz?
    tks a lot
    Quote Originally Posted by ecuprogramer View Post
    aqua_life
  8. The Following User Says Thank You to zzappy For This Useful Post:
    ars1 (4th February, 2023)
  9. #6
    Oct 2021
    cześć, czy mogę dostać hasło, plz?
    bardzo dziękuję
  10. #7
    Oct 2021
    tks a lot
  11. #8
    rafal's Avatar
    UK - PL
    Quote Originally Posted by WSERVICE View Post
    tks a lot
    thread 1 year old m8................. who will remember pass ???
    need help
    who will help?
  12. #9
    Oct 2021
    Quote Originally Posted by aqua_life View Post
    I have an identical problem. Can anyone help with this topic?
    I am attaching my flash file.
