Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: Dc/ac inverters
  1. #16
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by super jumbe View Post
    For best result get 6000W inverter and you need new caravan battery connect direct to your main van battery, with all that you can cut keys and use all electrics all day long.
    Without battery balancing it's killing your batterys. Plain and simple.
    Sir, are you classified as human? Negative, I am a meat popsicle
  2. #17
    maaxxyy's Avatar
    North Pole
    My bms is a balancer, you can set it to static balance or set it to balance whilst charging.
  3. The Following User Says Thank You to maaxxyy For This Useful Post:
    fred77 (5th June, 2020)
  4. #18
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by maaxxyy View Post
    Check this out, reasonable price to make a diy lifepo4 (what i use), but the bms they sell are a little on the high side -
    https://shop.gwl.eu/LiFePO4-cells-3-...u-case-CE.html
    And for a good bms with bluetooth (similar to what is use)-
    https://www.ebay.co.uk/itm/smart-BMS...Yd-El2K5dnYi7Q
    And for all the info you'll ever need on building a battery -
    https://www.mobile-solarpower.com/
    Will Prowse is a top bloke! Check him out on youtube, he has loads of videos on how to kit out your van or camper.
    thanks for links in end gone with
    https://www.aliexpress.com/snapshot/...Id=33035453389
    and
    https://www.aliexpress.com/item/3298...36e24c4d6dmeY0
    reviews are good
  5. #19
    maaxxyy's Avatar
    North Pole
    First link not working
  6. #20
    Feb 2014
    Guys, what you need all that power for - 4000W, 6000W ?!
    Are you making pancakes in there?
    Ours is just 800W(peak 1600) real sine from Victron attached to car battery and is quite enough for one key cutting machine (most machines are 150-200W max so at peak not more much more than 1000W) or a heat station.
    You always use just one consumer at the same time anyway.
  7. #21
    fred77's Avatar
    Jun 2019
    Yes and limited - so 12V x your battery capacity thus for me 12V x 200ah = 2400 watts.
    Inverver I've bought is 3000 watts just to be safe. Also cheap ones out there so hopefully money well spent. Victron good make.
    Powerwise everything can add up - key cutters are just 1 item im thinking battery support unit and hot air desoldering etc may all want to use at once.
    Sure overkill to an extent
    Youtube vids (very clever guy) -
    Bought this 20 amp DC-DC charger from USA
    https://www.youtube.com/watch?v=EcVjPap9dkY&t=108s
    Interesting page -
    https://www.mobile-solarpower.com/ra...eals-page.html
    Battery link -
    https://www.aliexpress.com/item/3303...00368-kR2gtZ32
  8. #22
    maaxxyy's Avatar
    North Pole
    Good choice, at least now you have a system which last a long time. Those cells look like CALB cells, which are good quality. Make sure you buy a decent bms for the battery pack with bluetooth preferably (phone app to set it up).
  9. The Following User Says Thank You to maaxxyy For This Useful Post:
  10. #23
    Nov 2021
    i have a large motorhome, with lots of electrical components :
    vehicle-battery 12V 80Ah LiFePo4
    camper-battery 12V 480Ah LiFePo4
    Generator 120V 6.5 kW running on LPG
    Transformer 120V/230V (bidirectional) 3.5kW
    Victron Multiplus 12/3000 120/16 = charger with 120A, inverter 3kW, also works as "booster" for the 230V line, the unit can be set to the rating of the supply-fuse
    DC-DC booster 12V 30A for charging while driving
    700 Wp solar with 5 panels and two victron mppt controllers
    Victron battery-manager
    The camper needs ~2A as base load ( 48Ah / day ), with heating etc. ~15A ( 200Ah / day ).
