Results 1 to 3 of 3
    Default Fiat Grande Punto 1.3 Multijet 75 HP remap problem
    Hello.
    Here is a problem:
    remap from 75 to 90 HP, safe mode turned on with following error codes:
    P0748 Pressure control solenoid "A"
    P0095 Intake Air temperature sensor 2 circuit bank 1
    P0045 Turbocharger/Supercharger Boost Control "A" Circuit / Open
    P0401 Exhaust Gas Recirculation "A" Flow Insufficient Detected
    Clean codes but no lucky as they appear again back and also safe mode again.
    Reflash original file, clean errors, everything ok.
    Remap file is officially made for HW/SW of My car ECU.
    Note that I have problems with safe mode sometime but cant connect it with anything as there is no particulare state when it will put it in safe mode (egr is off in original map).
    Any idea? Pressure control?
    Thank You
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    If with your original you have no problem, is a bad tuning....
  3. The Following User Says Thank You to Panathaole For This Useful Post:
    tom1 (6th June, 2020)
    Problem fixed. It was EGR. Removed and software disabled. Map flashed, no problems at all.
  5. The Following User Says Thank You to tom1 For This Useful Post:
    Panathaole (6th June, 2020)
