Results 1 to 5 of 5
Thread: Lishi KW17?
    keyprogramming's Avatar
    Default Lishi KW17?
    Trawled the net but can't see one anywhere for a 2005 Ducati ST3
    Does this Lishi exist?
    I've read the ignition with a Lishi KW14 reader, and get bitting 1122343
    I've cut a KW14 with KW14 setting, and cut a KW17 with KW17 setting, no joy with either
    Any assistance appreciated
    Newbie opencar's Avatar
    Nov 2015
    Quote Originally Posted by keyprogramming View Post
    Good afternoon.
    Unfortunately, LISHI does not have a KW17 profile
    The lock can be disassembled and the secrets can be calculated; you need to remove the contact group.
    Next, unscrew the two screws and you will have access to the fixing pin. By squeezing it, you will pull the cylinder out of the lock body.
    Fallen's Avatar
    Reverse the cuts 4433212
    rob h's Avatar
    May 2011
    Emulated the key cuts, with your lishi, outside the lock.
    And you will have a visual, of your key.
    Reversed or not,
    kemaster's Avatar
    BG
    Quote Originally Posted by opencar View Post
    Good afternoon.
    Better late than never))))))))
