Results 1 to 15 of 26
Thread: Saab 9-3 pin
    Oct 2018
    Northern Ireland
    Default Saab 9-3 pin
    Would someone be kind enough to give me pin for this car
    VIN: YS3FD46V571120548
    Thank you 👍🏻
    Apr 2016
    uk
    Quote Originally Posted by Jimmy07 View Post
    Thank you
    What do you want to do with the pin?
    For key programming remove cim and read eeprom 93lc66..
    Oct 2018
    Northern Ireland
    Bit extreme for a spare key
  4. The Following User Says Thank You to Jimmy07 For This Useful Post:
    p1et (12th June, 2020)
    Apr 2016
    uk
    Well, don't know what tool you want to use tfor programming by obd but many don't work as far as I know.
    It looks extreme to remove com but need only around 5mins..
    Sent from my MI CC9 Pro Premium Edition using Tapatalk
    Oct 2018
    Northern Ireland
    With known code MVP and other tools can add key if you have a working key
    Apr 2016
    uk
    I don't think it matters of you have a working key.
    As I said,5 mins to remove cim,read eeprom and make key..
    Easy job!
    p1et's Avatar
    Oct 2013
    Why on earth remove CIM for a spare key.
    PIN Code is: Z02E
    Apr 2016
    uk
    Quote Originally Posted by p1et View Post
    PIN Code is: Z02E
    I don't have access to Saab vin to pin.
    This is the way I do it. I find it very easy.
    It's a 5 mins job!
    What tools can program this key by obd?
  10. #9
    p1et's Avatar
    Oct 2013
    Yes if you don't have time access that's the only way. Some PIN codes are not in database so I must admit that having experience in removing CIM is always a good skill to have, just in case. All keys lost is a little bit tricky to remove CIM I heard? Because you can't turn steering wheel and get clear access to airbag clips / tabs whatever
    MVP Pro or Tech2 can program key by OBD if you have PIN.
  11. The Following User Says Thank You to p1et For This Useful Post:
    RG550 (13th June, 2020)
  12. #10
    Oct 2018
    Northern Ireland
    There is no way you’ll remove CIM and read eeprom and build back up in 5 mins
    But if that’s the way you do this for spare key that’s fair enough .......
  13. #11
    Apr 2016
    uk
    I said 5mins to remove cim..
  14. #12
    Oct 2018
    Northern Ireland
    I’m not having a go if that’s the way you do it and it works for you it works
    Anything to get job done and get paid 👍🏻
  15. #13
    Apr 2016
    uk
    Removing airbag is easy, doesn't matter if lost keys. Also, eeprom is easy to access and not dangerous like Opel cims.
    Don't have any of the 2 tools so I'll stick to remove cim..
  16. #14
    Feb 2020
    Read with vvdi prog generate with tango then write back with prog. Solder/Desolder is relatively easy with this.
  17. #15
    Oktawian's Avatar
    Sep 2016
    hitag2 can add key to the CIM dump, and remote will works as well.
    Queston for @P1et - can mpv programm key by pin with AKL scenario ?
