Results 1 to 12 of 12
    Default Renault Megane DF038
    Hi.
    I have renault megane II car not start.
    I do diagnostic and say me fault DF038 (internal fault in ECU). I have other ecu with same reference, I clone but same errors.
    I post eprom file and flash read with Renault Ecu Tool.
    The ecu is a SID301 S122326107A Siemens.
    Thanks.
  2. The Following User Says Thank You to serviclau For This Useful Post:
    Ocin (15th May, 2023)
  3. #2
    i think need virgin files.
    It's possible?
    any help please?
    Dec 2018
    write down eeprom with crc recount
    I think the CRC is 7168
    it's possible send dump with this crc?
    rafal's Avatar
    UK - PL
    Quote Originally Posted by serviclau View Post
    It's possible?
    if you have RET so you can do by self..................
    need help
    now my goal is to buy xp-005
    who will help?
    smokey08's Avatar
    Essex, UK
    Check wiring, I had one with a wire (orange I think) broken between the ECU and the upc.
    Sent from my Pixel 3 using Tapatalk
  10. #9
    i check again, but I think i wires is ok.
    If it's possible send me virgin file for this.
    Thanks.
  11. #10
    i check but not see any wires cut.
    no have any virgin file for this?
    Thanks.
  12. #11
    any have virgin file for this?
  13. #12
    Apr 2023
    Did you find the source of the fault? If you replaced the ECU and the fault was still present, it suggests the fault is elsewhere.
