Results 1 to 15 of 16
Thread: PCM FLASH
    Jan 2019
    United Kingdom
    Default PCM FLASH
    Anybody who owns PCMFLASH please contribute
    1. Does PCM do all VAG ecu via OBD VR or still need to patch ecu on bench?
    2. Does a passthru like VAS5054 work with PCMFLASH for OBD work, advantage of having the scanmatik interface?
    3. Are there any issues currently with the software?
    Thank you
    May 2017
    2. Scanmatik2 is the best for pcm. VAS5054 not work. Can also use Chipsoft j2534, Openport 2.0. I also want buy it.
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    What don't go obd can probably be done bench mode with module 71
    Jan 2019
    United Kingdom
    I have autohex so any tricore ecu inc latest MD1/MG1 i have covered, was thinking buy PCM for OBD, Kess slave about £1200, Master about £3800
    Mainly deal in Merc, BMW & VAG which mainly use VR OBD, costs £1000 for above options and seems well worth it, cant complain as long as everything advertised works
    Sep 2016
    PCM Flash is best for tool for edc17 med17,makes checksum also, to work on bench without opening the ecu ,connect only to pins via GPT , very stable and safe program, for PSA can use PCM Flash with Openport, for bench GPT EDC17 must have Scanmatic , but China ktm also does the job well.
    If helped, Rep and Thanks is highly appreciated!
    USA NGC3 NGC4 GPEC2 GPEC2A GPEC4 Stage1,MDS dtc egr cat evap off,all SeaDoo watercrafts limiters and tuning.
  6. The Following 2 Users Say Thank You to quato79 For This Useful Post:
    Dexxxx (6th July, 2020), Hayssam1 (4th April, 2023)
    Jan 2019
    United Kingdom
    Ktm china already tried, its ok doesnt work on some VAG ecu like CP44
    For obd work only the openport is enough or still reccomend to get scanmatik 2 pro interface?
  8. The Following User Says Thank You to amar28 For This Useful Post:
  9. #7
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by amar28 View Post
    in your first post you are only writing about VAG ECU´s...
    simos is also a VAG ECU, as like Magnetti Marelli are also used in VAG cars...
    so, yes if you like to work only obd, openport is the cheapest solution I think...
    MED/EDC17 is covered by VR, but also some SIMOS...
  10. #8
    DK Veteran daniel guerra's Avatar
    I think scanmatic is the best option, stable and reliable.
  11. The Following User Says Thank You to daniel guerra For This Useful Post:
    bondiblu (22nd June, 2020)
  12. #9
    Can PCMFLash do Simos 18.1?
  13. #10
    figani's Avatar
    Feb 2018
    Quote Originally Posted by golfather View Post
    no.................................................. .......
  14. The Following User Says Thank You to figani For This Useful Post:
    golfather (20th January, 2022)
  15. #11
    Member bendy's Avatar
    Mar 2009
    Essex, UK
    PCMflash,
    I use PCMflash with JLRmongoose, (as I already had this device) for obd and also got the power box which allows you to do bench work and also use's ktag's plugs and leads.
    So far no issue's, great support and service.
    Remember this is still a developing software, what is not on it today, could be added at anytime.
    It gets 10/10 from me
  16. The Following User Says Thank You to bendy For This Useful Post:
    golfather (23rd January, 2022)
  17. #12
    Quote Originally Posted by bendy View Post
    PCMflash,
    Thanks for the info, just ordered PCM Flash, with KTM box, which power box are you using? Also will need a OBD connection too, any you can recommend?
  18. #13
    Mar 2009
    Essex, UK
    Hi, I'm using genuine PCMflash not clone (ktm)
    Power box is PCMflash power box. Many dealers around sell this, got mine from ecutools.
    OBD Device i have is the JLRmongoose from drewtech which i can recommend.. all good no problems.
    There is other obd devices PCMflash advertise as working with their product.
    Hope this info helps
  19. The Following User Says Thank You to bendy For This Useful Post:
    golfather (24th January, 2022)
  20. #14
    Oct 2019
    someone tested module 26 over obd or bench obd? many thanks
  21. #15
    Feb 2018
    Ravensburg/Germany
    I use PCMflash (ori) with Modules 50 (VAG EDC17xx) and 58 (VAG DSG). So far one of the best tools i have, and also for reasonable price. Will add more modules in future, if there is interesting features.
    I use it with OpenPort 2.0, no issues until now.
  22. The Following User Says Thank You to GusGasfuss For This Useful Post:
    brmservice (30th January, 2022)
