Results 1 to 8 of 8
Thread: MED17.4 Virgin
    Dec 2011
    Default MED17.4 Virgin
    Hi guys have peugeot 3008 1.6THP 156BHP ecu bosch med17.4
    HW 9666319780
    SW 9666319780
    other numbers
    0261S04616
    9666325380
    Was read with Ktag done full backup and seperate micro and eeprom
    Reflash my ecu with micro only and configuration in my ecu gone, so want revert this reflash with my full backup same problem, with eeprom only same result.
    Was try to configure ecu using diagbox Ver. 8.55 app is freeze, autel maxsys same programming failed
    So my last option is Virgin my ecu, can anyone help with this please
    Thanks in advance
    Dec 2011
    Anyone can help me please ?
    esse's Avatar
    france
    Here................
  4. The Following User Says Thank You to esse For This Useful Post:
    blackangel82 (23rd June, 2020)
    Dec 2011
    Thanks pal
    Looks like driver inside ECU is fault
    Need to get another ECU not much of med17.4 is on eBay,
    Can I use mev17.4 instead of med17.4 make virgin or will not gonna work ??
    Have one mev17.4 from Citroen all plugs are exactly same
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by blackangel82 View Post
    Thanks pal
    med17.4 is med17.4 so no
  7. The Following User Says Thank You to ricked For This Useful Post:
  8. #6
    Dec 2011
    Hi, was bought from eBay another ECU from Citroen DS3 same engine and bhp.
    PCB looks exactly same 1 to 1 mcu etc.
    So I write my micro and virgin eeprom from my ori ECU.
    Have problem with configuration, even original diagbox won't let me to change config.
    After few hours playing downloading config from PSA server manage to config ECU, but getting error regarding identification ECU, and oil pressure
    Is anything what I can do to remove those errors
    Maybe is other way to clone ECU 1 to 1
  9. #7
    Dec 2011
    Hi, again anyone can remove fault code for me from micro in first post, faulty code F160A
  10. #8
    Dec 2011
    Was move mcu tc1766 to new ECU, but still can't configure ECU for my car. Looks like is stored some data in separate chip.
    Or which one is injector driver in med17.4
    Anyone can help please
