Results 1 to 10 of 10
    Feb 2016
    Default FIAT DUCATO EDC15C7 0281010489 IMMO OFF +NO MIL
    Hi mates, I have a client with a Ducato 2002 and have Bosch ecu 0281010489. I have read with programmer the 29f400bt and the eeprom 95080 memory. I tried to do everything through some software, but the MIL error ends up appearing. I have also installed Julie emulator, and although they support these units in their file, it does not work correctly. What options can I take ?. I think the defect may be in the eeprom part. Thank you all
    fiat ducato 0281010489 original cs04c3548d.rar
    FIAT DUCATO 0281010489 95P08.rar
    kiszka's Avatar
    Quote Originally Posted by tethirim View Post
    press buttons
    https://mega.nz/file/NnQRXSbb
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  3. The Following User Says Thank You to kiszka For This Useful Post:
    tethirim (2nd July, 2020)
    Feb 2016
    Hi kiszka , not necessary to modify eeprom to off the MIL light!?. Because i have a modified flash file, works fine ,but when i push the accelerator pedal the lights comes on
    kiszka's Avatar
    I think you have to look for other hidden faults
    in ecu by removing errors from the list in ecu
    you were hoping for a miracle if you did not describe the fault exactly
    I'm tired of guessing what exactly someone wants to achieve
    Reality of life :
    4:Everyone lies
    netherlands
    did you find a solution for ?
    Jul 2016
    Quote Originally Posted by kiszka View Post
    Have the same problem.
    Flash an EPP atached.
    Did you find any solution for the Check Engine light issue?
    kiszka's Avatar
    Quote Originally Posted by marimsa View Post
    eeprom is misread read it as 95p08
    and do virgin eeprom and it should be fine
    Reality of life :
    4:Everyone lies
    Jun 2022
    slovakia
    I'll say it once and for the last time for free. Use search. If you have problems with the check engine after adding gas, eeprom line 180, write complete to 00 00. Problem solved
  10. #9
    kiszka's Avatar
    Quote Originally Posted by kppow666 View Post
    I'll tell you one last time too
    your advice is good but with this erroneous eeprom reading you can put it in four letters for it to work there must be a correct reading
    you understand
    Reality of life :
    4:Everyone lies
  11. #10
    Jun 2022
    slovakia
    I didn't look at how he read the file, I say solving the problem with gas and check engine. Tested 100 times
