Hi, I read the 93C56 eeprom from bid display. I read the PIN is 1499. I need to pair it for other car.
Can someone unmarried this dump? Thanks
BID display AT
13 208 089
317099190
1024871-00
BID display AT
13 208 089
317099190
1024871-00
Decode Ghost (13th July, 2020), piokow14 (5th July, 2020)
Hi, I have the radio with deactivated theft protection by OPCOM, I understand I need to connect the display with your dump next connect the radio and activate theft protection with IMMO PIN ? Am I right?
Much thanks for respond
Decode Ghost (13th July, 2020), piokow14 (13th July, 2020), REZON (13th July, 2020)
Hello! There is a Opel Astra H in which radio Opel CD 30 (Blaupunkt) and a TID display were installed. It is necessary to install radio Opel CD 30 MP3 (Delphi Grundig) and BID display instead of them from another Opel Astra H (they work normally on the table and do not appear on the display noting like "radio safe" or "display safe").The radio and display dumps is attached. Help me to virginized them for the subsequent binding of the radio and display to the car with Tech2 tool (carpass is 1886). Thank You!
alexandr1966 (3rd November, 2020)
But the car have other carpass! Isn't it necessary to bind the radio and display to the car with a new carpass (1886)?
Normally, because we use Display to determine IMMO PIN for making keys,
it will work as is but some features may not because it's not original.
Correct way is to unregister radio & display before removing from old car.....
On the other forum you say you have TECH2... just use that..
wbr
I can unregister the old radio (CD 30) & display (TID) before removing from old car. But then I need to virginize the new radio (CD 30 MP3) & display (BID) before put them to the car? Because they are programmed with the carpass of another car (2220) and were not unregistred before being removed?
The set CD30 MP3 + BID display to be installed in the car cannot be unregistred from the car - they are purchased in the store as is! The car is not exist! They need to do a resetted to factory setting (virginize) and then be register them in the car as new with carpas 1886 using Tech2! Please modify my dumps! Thank You very much!
Perhaps I initially did not correctly explain the situation.
