    Junkyard Dog's Avatar
    Mar 2019
    EUROPE
    Default DSG DQ250 02E damos/mappack....
    Hi somebody have mappack or damos for:
    DSG DQ250E/F (02E)
    Part Number: 02E30051T
    SW:1909
    My file in attachments. Because i want pull up RPM because when i go 51km/h car put 5 gear. and RPM drop to 1350-1400RPM i want pull it on 1700-1800RPM. also i have log you can see km/h vs RPMs.
    Mar 2019
    EUROPE
    @31A48 12x4 1 / 2 ECO mode UP shift
    @31AA8 12x4 2 / 3 ECO mode UP shift
    @31B08 12x4 3 / 4 ECO mode UP shift
    @31B68 12x4 4 / 5 ECO mode UP shift
    @31BC8 12x4 5 / 6 ECO mode UP shift
    @32530 X-axis (pedal in %)
    @3256C Y-axis (Nm)
    is true?
    familiozo's Avatar
    Nov 2010
    Bulgaria
    Use this may be help you.
    IF I HELP YOU PUSH THANKS AND REP BUTTON
    Mar 2019
    EUROPE
    Quote Originally Posted by familiozo View Post
    i have this file.... with this i trying to find maps
    golf110tdi's Avatar
    Apr 2016
    EU
    Test and report. I change only upshift 4 to 5 gear. Let the tool correct the checksum.
    PRESS THANKS AND REPUTATION BUTTON IF I AM HELPFUL.
  6. The Following User Says Thank You to golf110tdi For This Useful Post:
    Junkyard Dog (11th July, 2020)
    UK south
    I would say your in the right area
    another video for you to watch https://www.youtube.com/watch?v=WnHOnDENFC0
  8. The Following User Says Thank You to bazaa For This Useful Post:
    moky (11th July, 2020)
