Hello there,
The recent theft and return of my 2007 E91 led me to explore car security software. The car always had only one key, so I decided it would be educative to try and program one myself.
Therefore I purchased several tools and already found some information on the internet.
The tools I have purchased:
- Hitag2
- R270
- E/F Scanner (only for E models, I know it’s a clone, but the real deal is a bit expensive for hobby).
- Several keys with blanc PCF7945 EEPROM chips.
- a 12 volt power supply for the car (more than 40 amps).
- BMW Tools (inpa/ista etc).
- A descent soldering kit (is still need practice)
I already succeeded in programming the blanc key trough the Hitag2. I figured programming the key tot the car would be pretty straight forward from there on, but I ran into some obstacles, which led to some questions.
The car being from 2007, I figured the cas module would be a non-encrypted Cas3 module, which should be programmable with the E/F scanner. Connecting the E/F scanner shows the CAS part number 9287535, which seems to be a 2012/2013 CAS3+ module. When I connect the E/F scanner and press key learning, it suggests “Update ECU?”, the internet already thought that there a lot of risks involved programming a CAS (especially with non original/clone hardware), so I did not dare to continue. I have looked around all over the internet, but I could not find any writing of anyone who actually clicked “yes”. So I have some questions:
- Is the 9287535 cas indeed a CAS3+ module, or is it just a CAS3?
- How can I tell whether or not the cas is encrypted with Ista-p 45+?
- What happens when I would actually click “yes”?
The car was stolen by OBD key programming (no signs of the cas being removed or loosened, but they did not bother putting back the loose door handle). I have a gut feeling that the key they used for stealing it was already programmed to the car before I purchased it. The previous owner also tampered with the mileage in a way that gave no tamper dot and similar mileage in all the ecu’s when we tried to check it with Carly.
- Given this car most likely has a CAS3+ / Istap-p 45, would it have been possible to program a new key trough OBD, and if so, how? VVDI2 claims it can do it, but is it actually reliably possible through OBD?
- This being a hobby and a bit of a challenge, what would be the way to go to program a new key? At this moment, removing the CAS and using a bench to get a EEPROM dump to program an existing key file into a new key seems to be the most sensible. Is that correct?
I do not lazily hope that you provide me with all the answers without doing any research myself. I tried to figure the above out, but I do not seem to find any reliable answers.
Thanks to anyone who can help me.
