Results 1 to 9 of 9
    Jun 2019
    Question Yamaha Aerox 50cc 2015 - speed limiter removal
    Hi,I have a question regarding 2015 Yamaha Aerox 50cc scooter. Max speed is locked at 50km/h, now how is this limitation achieved? Is the limiter in the ECU? Or there is something in the engine itself? If the limitation is electronic only, what can I do to remove it, what chip do I need to modify?
    Thanks in advance!
    EDIT: It's 2 stroke
    May 2019
    Macedonia
    Open the tranismition an look if got some ring on the variator if yess remove it or Look on the exhaust there are 2 blocks u need to remove change the exhaust with another gianeli pollini etc..
  3. The Following 2 Users Say Thank You to damjantuze For This Useful Post:
    Healow (14th July, 2020), teerak2uk (14th July, 2020)
    Jun 2019
    So there shouldn't be any electronic limiter? Only the limiter in the variator? There is also some closed pipe coming from the exhaust, they told me that's also the limiter and that I need to cut it off and wield the hole shut, is this correct?
    Nov 2016
    uk
    Yes if there is a pipe coming from exhaust with a blank end cut it off and weld a plate over the hole to stop it blowing. Tuned many 2 strokes back in the day...
  6. The Following User Says Thank You to liam987 For This Useful Post:
    Jun 2019
    And what about electronic restrict? Is there such thing?
  8. #6
    Jul 2019
    is this an efi bike or carb? i guess its carb
  9. #7
    Jun 2019
    Yes it's carburetor
  10. #8
    Apr 2016
    Remove locking ring from variator!
    Should run at 85/90km/h speeds without it.
    If you need more just with rev limiter increase.
    Check this out:
    https://www.pedparts.co.uk/bikes/yamaha/aerox-2013-on
    Br.
    Michael
  11. The Following User Says Thank You to SpecZ For This Useful Post:
    Healow (16th July, 2020)
  12. #9
    Jul 2018
    poland
    Blockades in scooters:
    - ring in variator
    - plate in carb (piaggio scooters)
    - plate between reed Valve and carb (piaggio scooters)
    - To Small main Jet
    - rev limiter in cdi module
    - Speed sensor on clutch Bell (china scooters)
    - blind pipe on the exhaust
  13. The Following 2 Users Say Thank You to socha1997 For This Useful Post:
    dule14786 (2nd June, 2024), Healow (16th July, 2020)
