    super jumbe's Avatar
    Livingstone
    Default FORD TRANSIT MK7 2012 2.2 Diesel BCM BODY CONTROL MODULE 5WK5 0309D programming hel
    Lads need your help, I have Transit van MK7 2012 with BCM water damaged, I have already bought used BCM how I can clone or programme the BCM, any help appreciated thanks.
    rob h's Avatar
    May 2011
    Have you openend it up?
    Should be cloneable, with Orange5, or similar prog.
    Would programming the new unit in be easier? Do you have a Ford tool?
  3. The Following User Says Thank You to rob h For This Useful Post:
    super jumbe (16th July, 2020)
    Meat-Head's Avatar
    Go stalk ninja123 think he drove 500 miles, then another 500 miles
    got used one from junkyard then corruption replace unit with avdi
    then he got second used unit and fixed
  5. The Following User Says Thank You to Meat-Head For This Useful Post:
  6. #4
    alex_r_2001's Avatar
    New Jersey ,, USA
    you should be able to use forscan ... it is free and works with j2534 or elm327 obd.... works great I use it all the time....
    foxtec800's Avatar
    get a used unit , yours ends in cc so it needs to be c and any letter on end ca cb etc but not ac bc they are low level unit.
    fit used unit, used forscan ids or avdi to read backup config from cluster and then write to bcmii.
    program your key or keys to used bcmii
    carry out pats parameter reset to learn bcmii to ecu and reset crash data tag if logged in bcmii from breakers.
    all can be done with forscan except keys and module initilization as its 2010> algo and forscan wont do that.
    but avdi will or ids with online account
  8. The Following 2 Users Say Thank You to foxtec800 For This Useful Post:
    Meat-Head (16th July, 2020), super jumbe (16th July, 2020)
  9. #6
    Livingstone
    Took both unit to our electrician and he repaired the old unit he told me one of the chip had dry joints all sorted now thanks all.
  10. The Following User Says Thank You to super jumbe For This Useful Post:
    Meat-Head (19th July, 2020)
