Hi all,
Im looking for a cheap programmer for this bsi and dashboard.
I have Vvdi prog, orange5, CG-QX4, xprog clone and minipro but cannot read this mcu. Im looking for a good and cheap programmer.
Hi all,
Upa-s elrasoft
carsandkeys (16th July, 2020)
I read in some post that people have problem reading nec with upa with nec adapter. I think in tool like ETL nec but this only work with com port and old windows version.
Hi I use ETL prog for this chip and always working no problem ,,,,,but u must connected 14 wires and some legs MCU lift up ..and have old PC witth serial port ..windows XP recommended
Hi, if you buy original uupa and original NEC adapter, no problem to read nec mcu friend.![]()
The thanks button does not burn, you can press it without any risk !
Hello to all. I have bouth upa-s and necprog, they work good. Here in DK I have posted solution to repair pcb at china nec adapter, after this mod it is working 100%.
Yhoni (27th June, 2022)
There is no problem with reading upa-s
Ori NEC adapter or mod clone.
https://www.digital-kaos.co.uk/forum...PA-nec-Adapter
Then i will try get Upa with the original nec adapter. Thanks
