Results 1 to 12 of 12
    Default Audi A6 2012r 0285010856, 4H0 959 655 C
    Hi to all,
    have someone pinout for this unit to make connection on bench?
    And maybe clear crash data from 95640?
    Thanks in advance.
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Photo socket srs unit ? And clean up your pm box, full ...
    Scripts for Multi-PROG
    Best regards.
    Dragon
  3. The Following User Says Thank You to dragon100 For This Useful Post:
    Hayssam1 (15th April, 2025)
    I found connection on bench and how I can see I have not messager for crash, but if you can, please clear me damp.
    For someone who have not connection picture is attached.
    dragon100's Avatar
    Jan 2012
    Which errors ?
    I think if no crash error, then check crash counter in measuring blocks ...
    Best regards.
    Dragon
    I have one crashes (frontal):
    Number Of Frontal Crashes
    Measured Value Identical 1
    Number Of Activations Of Pedestrian
    Protection
    Measured Value Identical 0
    Number Of Rear Crashes
    Number Of Rollover Crashes
    This is full errors on bench:
    Diagnostic Scan
    Vehicle diagnostic report
    Shop Name:
    Address:
    Phone:
    Email:
    VIN:
    Year:
    Make: Audi
    Model:
    Odometer:
    Vehicle Software Version: V28.66
    Diagnostic Application Version: 3.13.041
    Test Time: 2020-07-26 10:45:09
    Diagnostic path: System Selection > 15 Airbag
    Inspection Result
    Diagnostic Result
    B101E15 Seat Position Sensor, Driver Side - Open Circuit/short Circuit
    To B+ Active/Static
    B101F15 Seat Position Sensor, Front Passenger Side - Open
    Circuit/short Circuit To B+ Active/Static
    B102715 Front Passenger Seat Occupant Sensor - Open Circuit/short
    B101A15 Crash Sensor For Front Airbag, Driver Side - Open
    B101B15 Crash Sensor For Front Airbag, Front Passenger Side - Open
    B101715 Crash Sensor For Side Airbag, Driver Side - Open
    B103615 Crash Sensor For Side Airbag, Front Passenger Side - Open
    B101815 Crash Sensor For Side Airbag, Rear, Driver Side - Open
    B101915 Crash Sensor For Side Airbag, Rear, Front Passenger Side -
    Open Circuit/short Circuit To B+ Active/Static
    B10001B Driver Airbag Igniter - Resistance Too High Active/Static
    B10021B Passenger Airbag Igniter - Resistance Too High Active/Static
    B120E1B Driver Airbag Release Valve Igniter - Resistance Too High Active/Static
    B120F1B Igniter For Frt. Pass. Air Bag Release Valve - Resistance Too
    High Active/Static
    B10151B Igniter For Battery Interrupt - Resistance Too High Active/Static
    B10131B Driver Side Belt Force Limiter Igniter - Resistance Too High Active/Static
    B10141B Front Passenger Side Belt Force Limiter Igniter - Resistance
    B10061B Driver Side Seat Belt Tension Igniter - Resistance Too High Active/Static
    B10071B Front Passenger Side Seat Belt Tension Igniter - Resistance
    B10051B Driver Head Curtain Airbag Igniter - Resistance Too High Active/Static
    B10041B Front Passenger Head Curtain Airbag Igniter - Resistance
    B100B1B Driver Thorax Airbag Igniter - Resistance Too High Active/Static
    B100A1B Front Passenger Side Airbag Igniter - Resistance Too High Active/Static
    U112100 Databus Missing Message Active/Static
    with vcds I have crash data stored:
    26 Faults Found:
    9437210 - Igniter for Driver's Airbag
    B1000 1A [136] - Resistance Too Low
    MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
    9437211 - Igniter for Driver's Airbag
    B1000 1B [137] - Resistance Too High
    MIL ON - Confirmed - Tested Since Memory Clear
    9437723 - Igniter for Passenger's Airbag
    B1002 1B [136] - Resistance Too High
    9440027 - Driver's side; side-airbag igniter
    B100B 1B [137] - Resistance Too High
    9439771 - Front Passenger's Side Airbag Igniter
    B100A 1B [137] - Resistance Too High
    9438747 - Igniter for Seat Belt Tensioner; Driver's Side
    B1006 1B [137] - Resistance Too High
    9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
    B1007 1B [137] - Resistance Too High
    9438491 - Igniter for Driver head airbag
    B1005 1B [137] - Resistance Too High
    9438235 - Igniter for Front passenger's Head Curtain Airbag
    B1004 1B [137] - Resistance Too High
    9440283 - Driver side knee airbag igniter
    B100C 1B [137] - Resistance Too High
    9451547 - Igniter 1 for pedestrian protection
    B1038 1B [137] - Resistance Too High
    9451803 - Igniter 2 for pedestrian protection
    B1039 1B [137] - Resistance Too High
    9447189 - Seat Occupied Sensor; Passenger's Side
    B1027 15 [137] - Open or Short to Plus
    9443349 - Rear Side Airbag Crash Sensor (on driver's side)
    B1018 15 [137] - Open or Short to Plus
    9443093 - Driver's Side Airbag Crash Sensor
    B1017 15 [137] - Open or Short to Plus
    9443605 - Rear Side Airbag Crash Sensor (on front passenger's side)
    B1019 15 [137] - Open or Short to Plus
    9451029 - Crash sensor side airbag; passenger side
    B1036 15 [137] - Open or Short to Plus
    9443861 - Driver's Front Airbag Crash Sensor
    B101A 15 [137] - Open or Short to Plus
    9450005 - Pedestrian Protection Crash Sensor (driver's side)
    B1032 15 [137] - Open or Short to Plus
    9450261 - Pedestrian Protection Crash Sensor (passenger's side)
    B1033 15 [137] - Open or Short to Plus
    9466352 - Crash Data from Belt Tensioner Stored
    B1071 F0 [137] - Unknown Error Elaboration
    9447424 - Front crash data stored
    B1028 00 [137] - -
    9448704 - Pedestrian Protection Crash data stored
    B102D 00 [137] - -
    9735428 - Pedestrian Protection Crash Sensor 2; Driver Side
    B148D 04 [137] - Internal System Fault
    9735701 - Pedestrian Protection Crash Sensor 2; Passenger Side
    B148E 15 [137] - Open or Short to Plus
    16712550 - Internal Control Module Memory Check Sum Error
    B2000 00 [136] - -
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Tuesday,13,November,2018,21:44:33:52069
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 18.9.0.2 (x64)
    Data version: 20180927 DS296.0
    www.Ross-Tech.com
    and couner with vcds after clear errors:
    Address 15: Airbags (4H0 959 655 C)
    11:38:38
    IDE01555 Number of frontal crashes 1
    IDE01556 Number of side crashes driver side 0
    IDE01557 Number of side crashes frt.pass. side 0
    IDE01558 Number of rear crashes 0
    IDE01559 Number of rollover crashes 0
    IDE01560 Number of activations of active head restraint 0
  10. #9
    robert1232's Avatar
    Dec 2010
    Ireland ;)
    Default here is your file
    press thanks+reputation=pass
    raport here
    Quote Originally Posted by zorans View Post
    Hi to all,
    Thanks in advance.
    PRESS THANKS AND REPUTATIONS (STAR) BUTTON
    I don't give others the password to the file. I'll send my file and I'll try to make it
  11. The Following User Says Thank You to robert1232 For This Useful Post:
    zorans (26th July, 2020)
  12. #10
    after clear errors, counter is again 1 for frontal crash but on error list have not : 9447424 - Front crash data stored B1028 00 [137] - -
    Is it ok or need to manualy clear crash data in 95640?
  13. #11
    Please pass.
  14. #12
    dragoshu's Avatar
    Aug 2016
    Dacia
    I have srs with crash data stored and after clear with vcds on bench desapeer crash,I have attached 95128 eeprom if sombody can chek for me crash data inside eeprom.
    4H0959655H
    0086
    H82
    BOSH 0285011977
    AUDI A6
    If I help you dont forget to push thanks button
